datamaster problems ??? anyone ... bueller????
G
Guest
Guest
DOse anyone have problems running datamaster .??? I always get early pcm when i check the com port-cable . I have changed the serial communication timing for hours the program seem to work intemetantly around 198 on the serial timming.. any one ? I have a compact 1800t laptop-450pent.3 check two diffeerent cables. thanks- cheatham
crsurf1
I get that on both of my IBM Thinkpads including a P-III 450, but they still work. The 266 takes 2 - 3 seconds before it starts logging where the 450 immediately logs. As long as it's logging it doesn't matter about the "Early PCM" dialogue box.Just keep playing with the setup and maybe you can get the ideal setting.
Craig
Tooky
Serious about performance
Try getting someone whose laptop is known to work perfectly in their own truck, and try it on your truck.
You may have something specifically interfering on your truck. Syclone892 from Waterford, WI (David H.) had this exact problem and I'm sure he could tell you more about it. I tried my laptop on his truck and it worked only intermittently and would often fall out of sync no matter how I adjusted it. He bought some type of filter from Radio Shack and I do believe that solved the issue.
PS: My truck has always worked with all 3 of the Compaq laptops I've used, and my VIN is #0044 with original ECM, DataMaster does say "Early PCM" but clearly it does not hamper my datalogging communications.
Phoon30
I had the "early PCM detected problem when I first started using my Datamaster. I Got in touch with Andrew from AKM cables (amattei@mindspring.com) and he gave me a link to an online trouble shooting guide for Datamaster and I went through all of it and it fixed the problem.
G
Guest
Guest
Hay thanks for the feed back. I tried it out on a friends laptop with not one error..... .So i think now that maybe the ecm is malfuctioning, is there a way to tell?? Befroe i buy a new ecm 157.00 shipped from gm parts direct. i will try the trouble shooting site . Dose anyone have the site on hand? maybe just maybe that will work. but with the problems i have bein having lately i think it will cost me the money. Thanks PS> my $%#%^&^ typhoon eats more money than a bitch.....................
G
Guest
Guest
I meant "tried it out on a friends typhoon.." . Damn-spickolley
Syclone#892
I don't know if this helps out at all or not for you but the filter TookyCat was referring to was a noise filter made by MSD because my truck has a MSD box on it and it was causing interefence so I installed the filter and now datamaster works flawlessly. Hope you find your problem.
G
Guest
Guest
Yea, actually I have an MSD 6A mounted on the fire wall. Dose any one know the part # of the ignition filter,and where i may purchase one? Summet??Thanks agian for all the info.. cheatham
<font size=-1>[ This Message was edited by: cheatham2492 on 2002-01-18 04:06 ]</font>
<font size=-1>[ This Message was edited by: cheatham2492 on 2002-01-18 04:09 ]</font>
Syclone#892
Here is the part# 8830. Its a little red cylinder, very easy to install and it totally solved my problem, hope everything works out for you. Email me if you have any questions.
P.S. TookyCat my name is David V.H. last name is two words, just letting you know.
Tooky
Whoops, that was a mistake on my part, I didn't mean to skip the V. I only get 3 initials so you 4-initial people have to give me a little break :smile:
