Datamaster Q's
TYTILIDIE
METH HEAD
First off, how do you put a run to a PC? Or i.e. how do I get it on the board? Second, my IAC is fairly new and it never goes above 6-10. Knock, when my truck is running "not as good", I get a max of 3-4, when its running like a raped ape, I get 5-8. What are normal VE's? ANd last, would anyone be willing to look at my runs? Any help is always appreciated.
Mike
bezerk
if you are talking about 6-10 KR, that''s way high
you know how to upload a pic?
basicly the same as the datamaster file.
TYTILIDIE
METH HEAD
That wasnt quite what I meant. I meant how do I get it from my laptop to my computer, sorry for the mix up. And yes I realize 6-10 KR is way high. But what I cant get is why its not always the same. Some WOT runs show from 1-4 others (days) from 6-10.
Mike
SeattleSy#1255
Category 5 Conservative
you mean laptop to desktop? just save it on a disk and upload it. install datamaster on your desktop too.
knock, could be temp outside, gas you are using, overboosting vs. not, from a roll vs stop, false knock, shifting, and of course other things that change day by day.
sytyguy
Moderated User
VE varies too much to pinpoint a "normal" or average. What RPM? kPa? Spark Advance? Camshaft? Turbo? Heads? Exhaust? For the sake of argument, an engine is basically an air-pump so any change to it (in any way) will cause a change in the overall efficiency of the engine itself. Far too many variables as you see.....
Size of DM run? Again, it depends......on # of frames/sec recorded, length of time recorded, etc.... However, a 4-5 fps run for 30-40 sec will usually be around 200K (small enough to fit 5-6 comfortably on a formatted DD floppy).
BTW, don't go by the VE reading on DM. It's not accurate as it feeds off of the stock narrowband O2 sensor. For accurate VE, grab a wideband and use as a standalone or integrate into the chip (and DM) via Dig's patch code. Tons of other posts out there about WBO2s and the patcher code.
HTHs
Hood
