Have not seen it mentioned here so... DM has been updated to run on Vista & W7. Otherwise no difference. You will need a new auth. code. I assume that you just ask for the code if you've already paid once. I don't think you need a code just to read your file. Only to record data.
"DataMaster version 4.00 has been updated for compatibility with Windows Vista and Windows 7. Windows 98 & earlier are no longer supported. There are no functional changes in version 4.00 compared to prior versions.
IF YOU INSTALL VERSION 4.00 YOU WILL NEED A NEW AUTHORIZATION CODE.
DataMaster v4.00 may be co-installed along with earlier DataMaster versions without interference."
http://www.ttspowersystems.com/DataMaster_downloads.html
