DB9 to USB Serial adapter
Captain Morgan
Moderated User
ok, i picked up the Belkin Serial/USB adaptor, got it all installed, hooked it up to the laptop and the truck, little red and green lights come on and blink and shit, but fuckin Datacrapper will not allow me to select COM 4 as the port I want to use. any ideas on this one?
Captain Morgan
Moderated User
ok, well i thought I had it figured out. My modem was on COM3 which is the only port Datamaster would allow me to use, so I moved the modem to COM4, and reinstalled the USB software. Well, I thought it was a success, as the Belkin thing was now on COM3, but now Datacrapper has decided it wants to only allow COM4 to be selected. Why the fuck does it keep wanting to go through my damn modem!!!!!!!!!!! :evil: :evil: :evil:
ed hess
race or get outta the way
does your bios or windows allow you to reconfigure your comports. ie
Also,
what is curently on com1?
on com2?
on com3?
on com4?
lBoot up into your bios settings and see if youcan configure your serail ports there.
I think you can reconfigure your com ports in device manager.
Not sure if you can redirect com ports as you can lpt ports.
An edit of the system.ini file might be helpfull to do this.
the laptop vendors website may be helpfull for this.
ed
Rufus
You have to assign the Belkin to a com port 1--4 using the Windoze device manager: (USB can assign up to port 255!)
1. Open the Windows Control Panel.
2. Select "System" - this will bring up the System Properties form.
3. Select the Hardware tab
4. Press the Device manager Button - This will bring up the Device Manager form
5. Select the Ports(Com & LPT) category. The Belkin USB serial port adapter should be present
Double-click the USB Serial Port item to bring up the properties form--
Go to the Port Settings tab and verify 9600 Baud, 8 data bits, No parity, 1 stop bit, no flow control is selected:
Next, click the Advanced button to bring up the Com port number and FIFO Buffer settings--
Make sure the Use FIFO Buffers option is selected, and then set the Receive Buffer and the Transmit Buffer settings both to 1 (one). This will give the fastest response time for the USB serial Port.
Also note the COM port number that is selected. DataMaster must match this setting, and is currently limited to COM1..4 settings.
--MAKE YOUR SELECTION HERE! If it wont allow you to select a port between COM 1 through 4, something else is using them (like an IR port or modem). In that case, you will have to use the device manager to disable one of the conflicting devices.
Occasionally, the USB serial ports do not respond the first time they are accessed after they are reconfigured. It may take a few connection tries or a system reboot for the settings to take effect.
Good Luck,
Gary
Captain Morgan
Moderated User
Also,
on com2?
on com3?
on com4?
ed
WOOHOO!!!!!!! I think I got it working!!
I had to disable the CCM Handshake (is that ok?), and I think I have the ALDL Link timing in the 190's. Should I try and pinpoint where it works best? or once it works, it doesnt matter?
Ed, to answer ur question, no i cant reconfigure the COM ports.
I have no Idea whats on COM1 or 2, COM 3 is the Modem (from previous post) and COM 4 is now Datamaster.
It doesnt matter now, it works I think, well I recorded a run anyway, for those who would like to download it, Click Here!. Its just a crappy 0-70 launch, nothing special.
Rufus
Yes you MUST use the disable ALDL handshake to work with the USB adapters. And, it turns out the the ALDL timing is ignored when this is done, so dont bother experimenting with this!
Gary
