Dead turbo?
T-Bone
Re: Dead turbo?
CodyTY23 said:
what are the signs onf a dying turbo? dead turbo? any help is apprecitated guys
No power (failure to build boost), lack of spool sound OR excessive metallic noise from turbo and metal fins laying near your exhaust tip.
SY2932
Administrator
Re: Dead turbo?
CodyTY23 said:
Does the turbo just go bad all of the sudden or does it take a period of time?
When you have a rotating assembly that spins at 130,000 to 140,000 RPM (that is what the stock turbo spins at making stock boost) the damage happens in the blink of an eye. Usually if the wheel seizes up, it puts a hole in the housing as it exits... Some side to side play is normal but thrust (in and out) is bad.
mrweelr
Re: Dead turbo?
Lots of blue smoke out the exhaust, loud screeching noises, no power, oil dripping out of downpipe. Ask me how I know...
T-Bone
Re: Dead turbo?
92boostedty said:
when my turbo spools it sounds a lot more high pitched then usual what does that mean?
You might have a female impeller installed in it???
Flyin Ryan
hated cuz he drives fords
Re: Dead turbo?
Changes to the intake track on stock turbo'd trucks can increase the turbo spool sound allot.. adding an exhaust dump or cutout will also increase this wonderful noise.. If your turbo builds boost fine and doesn't smoke I'd check to make sure it's not rubbing and if that's cool then I wouldn't worry about it much.
