Diacom BLM @ 138...
SyTyJedi
Jedi Council
What does this mean? I know that normal is in the 128 range.
I used to have a document that explained everything that diacom read and what each thing did, etc...I cannot find it. Anyone have such a file or can anyone point me to a resource to study up on this?
TIA!
Tyler
Daron
BLM numbers equate to injector "on" time. So if the number were to go up, you could deduct that the ecm is correcting for a percieved long term lean condition. Some say that a change of + or- 10 isnt a biggie, that to worry if it exceeds that. It could still be an indicator of a fueling issue. How is knock? Plugs?
kwick6
Tyler,
I guess from what I read in the archives there are two BLM tables, one for idle, and one for off idle. Interesting stuff. Here is some things I found.
Sounds like you want to pull the ecm-b fuses to get your truck to *re-learn* when you change things, such as fuel press, or vacuum.
So if this is correct you should see different numbers from when you are on and off the throttle.
So when are you seeing the 138 @ idle or cruise??
HTH.
Scott
Hi Eric,
You may have to labor for this one.. <grin>
you didn't mention whether you have a stock cam or
which chip you are using. I'll assume you did not change
your cam, and vacuumm levels are good, and there are no
vac leaks.. Most aftermerket chips have stock or close-to
stock idle fueling, so let's dismiss that for now..
Just a guess here, it sounds like the ECM may be over
compenstaing for excess FP at idle. 50 psi sounds a little
high IMO. That's 11 psi over stock. BUT, ideal FP depends
on lots of things, so don't take my opinion as rule. A good
place to start would be to warm up the truck and after you get
the rough idle to occur, drop the fuel pressure by 10 lbs, shut
it off, pull and reinsert the ECM fuses.
Next, restart the truck and see if lower FP and a "cleared"
ECM have any effect.
If they do, you may want to keep the FP a little lower.
Not necessarily 10 lbs lower, but "lower" is up to you...
The best way to get a handle on what it is you're fighting,
is to hook up a scantool or Diacom, and "look around"..
Pay particular attention to BLM numbers after warm-up.
They should be right around 128.. If the BLM numbers
are 10 or more+ to the low side, that means the ECM sees
a prolonged rich condition and is working to correct the
problem by leaning things out (at all RPMs).. That is
your cue to remove some FP from the equation. Having
"HIGH" BLM numbers, on the other hand, is just as bad..
It means your situation is being percieved as 'lean" by the
ECM, and should also be corrected (by you).
If your recent rebuild included a new cam with considerably
more duration, ignore the above stuff for now, get a diacom,
and email me directly.
HTH
Mike V
..the BLM *does* get applied if the BLM is lean at the
time you enter Power Enrichment mode (WOT).
In other words, if the ECM has "learned" over a long period of time
that the engine is lean, then it will apply that "fudge factor" to
the overall fueling equation, even at full throttle. This is why a
bad o2 sensor can potentially affect WOT performance.
If the BLM is reading "even" or richer than normal, it will not
add that factor to the overall fueling.
The BLM does't get calculated during WOT (Power enrichment) either.
It won't try to tell if the engine is too lean/rich if you're on
the throttle hard, it will only "learn" at part throttle and idle.
