diy-wb
smeagol
Yup, Dig's done several, I have 5 of them in the works, Jim Sloan is already using his.
I have the old one, but same buildup technically.
We've even datalogged the wideband 02 signal using the stock ECM, so it can be read out on Datamaster & Diacom.
This is how I dialed in the 50# beta chip (still have a bit more to do).
Definitely awesome price for the accuracy.
Ian Turgeon
Cascading Inspiration
Im interested, where would I be looking to get parts? anyone have some good leads on cheap o2's or any usefull info to add
smeagol
Read all the info on the page that Jim posted. Gots all ya need. All the part numbers from Digikey, the sensor details.
I thought we had a lead on some cheap 02s for it, but turned out to be wrong. You can find some used sensors, but better to be safe than sorry and get a new one if you are going to put much stock in the readings.
Cheapest I've heard new is $120..
Parts are $20-25 I think.. not including board.
BigAl...
Hey BG I've just ordered the parts, I'd like to know more about interfacing it with the stock ecu so I can have the values show up on the datamaster.
TIA
BigAl...
smeagol
Need to change stuff in the chip.
Have to get Dig's permission to let his code out, as his works well.
BigAl...
that would be great, assuming dig gives the ok would you then reburn me an updated chip? how much$
TIA
BigAl...
smeagol
Need to see what Dig's stance is on the code.
I don't want to step on toes, and I ain't one to steal others' work.
If he doesn't want to let it out, I have my own code I can alter & figure out. I just know his is proven.
B
Blake
Guest
Brian,
I hate to say "me too" but I would like to know how to use this as well. Dig sent me a little info but I was kinda at a loss as to what to do with it. I'd imagine he left a little bit out here and there, it seemed kinda cryptic. He also sent me a site to order the pcb from and I filled out the order but never heard from them again. Would I be better off just buying the one from above mentioned website? At least I would have one then. Just tell me what you guys need so I can get in on it. You guys should've been working for GM when they came up with the syty. Wide bands would probably have been mainstream by now :smile:please let me know.
George Blake
kwick6
I would like to get one of these, but not really feeling confident about my soldering skills. I couldn't imagine what it would be like to have a *real* AFR to look at.
AFAIK, you want a WB so that you can look at your WOT AFR. Most people shoot for one around 12.0:1 , though that can vary with different trucks.
Falco
Yep. Going via the stock ECM would be really great. On the other hand I really appreciate Dig's and BG's work so it's up to them to let it out or not.
Rgds,
