DM: jumping O2mV ??
dirtdemon
"mr. ghettowrench"
hi - it's me again w/ another Q :
yesterday i finally got my IC-pump fixed *hehe* and did a DM run ...
... what confuses me is :
at idle and at low speed my O2mV 's are jumping in a 1/10 of a second, sometimes down to ~ 44mV is this normal, or if not - was does that tell ???
also i recognized that my InjDC is sometimes up to 113% - can i reduce that (w/o swapping to bigger injectors) ???
what value should the O2mV's show at WOT to run save - mine is around 840, kinda lean, huh ? (outside temp. around 8°C) ...
... or will it help to send the whole DM-file ???
... please do me a BIG favour and have another quick look at my file :oops:
:colors:
TIA,pat.
Re: DM: jumping O2mV ??
:colors:
TIA,pat.
The O2 Sunsor should oscillate from ~100-900mV in closed loop. What is important is the cross counts are constantly moving and the voltage is varying. Under WOT I would guess your lean, narrow band o2 aren't accurate enough WOT to predict a specified votlage, but it should be up over 900mV.
