do i need new injectors?
Mephisto
These trucks are cursed
ive been chasing this fueling issue for quite some time now... so let me state the facts then those who want to can voice their opinion.
for quite some time my truck has been "bogging" under boost, meaning im getting 17psi on the boost gauge, and the truck just aint movin! now ive done several datamaster runs and played with fuel psi, and no matter what the exhaust smells rich, and datamaster says the short term counts are 0.0% yet the long term are +17.2%(@WOT), now after reading a few posts ive heard its possible for the ultimate to cause some problems, so i pulled the ultimate out and ran stock. datamaster run results came up the same, +17.2%(@WOT), also with the stock chip i was getting some crazy ass knock retard spike from 4* up to 12.7* as soon as i hit 100mph (on 91oct). i have no idea whats up with that, since it wasnt doing that with the ultimate... doesnt the "T1" setting have the same amout of advance as stock?
anyway my question is, is it possible my 02 sensor could be bad? it appears to be reading accurately per datamaster, my 02 volts are in the 900s. im just thinkin if maybe the 02 is eff'd up and reading the wrong amount of airflow its telling the ECM to send more fuel???? thats the only other thing i can think of, other than the injectors are toast. at this point all i know is that its running rich, no matter how i the adjust fuel psi.
any opinions are appreciated! TIA
Tooky
Serious about performance
When you shut off the truck does your fuel pressure drop immediately on the fuel pressure gauge?
nightdiver
Whats the air fuel ratio by the time it starts jerrrking ? may be its a wire ,spark plug thing(most possible with our trucks)
Falco
Have you tried higher octane? Do you replace the MAP sensor too when changing between stock and Ultimate? Do you have the stock thermostat?
Anywa, Ultimate T1 is very near to stock, timing wise.
Maverick87,
I'd say that kind of fule pressure loss is normal...
Later,
Mephisto
it still runs rich even with higher octane, and like maverick my fuel psi takes about a half hour to drop. also, i did swap the MAP sensor when changing chips.
those of you who have installed injectors, is it a bitch, or an easy install? if its something that can be done relatively quick i.e. hour or 2, i might just borrow some injectors and swap em real quick to see if that is my problem.
i appreciate the input!
Falco
If you remove the upper intake the injector swap is not a big deal. However an alternative to the swap could be to get an injector pulse tester. You can test your injectors this way without removing them. If one of them leaks, it will show up...
Later,
leroy
I'm just curious how you can smell rich exhaust under wot? I've got some weird images running through my head about that.
At any rate, you're not running closed loop at wot, so I wouldn't pay much attention to the long term counts. That leaves the bog under boost problem. With 91 octane, I would expect a lot of knock retard with either chip. I'm not sure why it doesn't show up with the Ultimate. Think about repeating that test. Look at spark control counts, and spark advance as well.
I would suggest a higher octane, running less boost or less advance before swapping injectors. If your injectors are bad, you are more apt to run lean than rich, I would think.
HTH,
Jim
Mephisto
what i meant was the exhaust smells rich at idle.
as far as knock goes, i dont really get that much on 91oct. maybe 4-5* at the shifts, and its the same whether i use the ultimate or stock. but for some reason i was getting that weird 12.7* spike as soon as i hit 100mph using the stock chip. when i use 101oct, i barely get any knock at all, maybe 2* at the most on either chip. when i did these tests i used a stock chip, and my ultimate set to T1-16.
the only reason i suspect the injectors are the problem, is because i had a similar problem with my 94 blazer.. when i got on the gas it would bog out and not move, it smelled like gas and i started getting shitty mileage. i heard there was a recall on the injectors, so i took it to the dealer and they replaced them... after that... problem gone...
the way i understood it, was that an injector sprays gas into the cylinder in a "mist" form, resulting in a fast and efficiant combustion. but if the injector is bad and is just flooding gas into the cylinder, not all the gas combusts, resulting in weaker combustion, hence loss of power, and the unburned fuel going out through the exhaust? does that sound right or do i have it all wrong?
maybe im crazy, but that seems to be my theory on whats wrong.
i just wanted to know if anyone had ever had a similar problem and what they did to fix it.
on datamaster what kind of BPW/INJ DC stats should i see from a normal working injector?
on one of my runs, my BPW averages around 16 but jumps around a bit up to 17 and down to 10 and the INJ DC is just as bad going from 110 then jumps up to 130, back to 110-117 then dives to 80 then back up again. (this happens while @WOT)
