drilling for rocker studs
NecroWolf
lost marbles member
i'm just verifying that i got the right idea in my head. i'm getting ready to put arp rocker studs in my vortec heads. all i need to do is center over the already drilled hole and enlarge it to the appropriate size and tap it for the right thread correct?
Re: drilling for rocker studs
MikeRenz said:
or you can just buy arp metric conversion bolts and not drill anything
Unless ARP (or someone else) has started making a new set, the ARP metric conversion studs are the wrong length.
Syclone #1721
I LOVE 4UM SUPERSTARS
I strongly suggest not drilling them by hand. I mean yea you can do it and I know some people will say they did it without a problem but if they are off a little bit, it will affect your rocker arm geometry and cause irregular wear of the rocker stud especially if you are using aftermarket rockers. Take it to a machine shop and have it done. Its not that expensive and will make a big difference. While they are there, have the guides cut for positive seals.
MikeRenz
not stock
they worked for me :dunno:
NecroWolf
lost marbles member
i will probably fire up my trusty drill press for it, but i'm looking for a shop to cut for over sized valves so i might let them do it i i can find a decent price on it.
jslezak83
Soon-to-be BoostedBlazer
i just did my L31 Vortecs. i didn't drill anything. the holes were just a tad bigger than the "O" bid you need for 7/16"-14. the studs i baught where 7/16", with 3/8" shank for the rockers.
NecroWolf
lost marbles member
you probably have the older heads. they used a 10mm bolt, the newer ones use an 8mm bolt
MikeRenz said:
I used 100-7201
Ed Hess used 135-7201
I have no clue what the difference may be.
135-7201 arp big block chevy 496 ci. longer stud length for rocker arm nut or poly lock.
ghettosled
SYTY SUPERSTORE
wrong length for full bodied rockers, but work fine for cup style or roller tip. You can make them work with full roller rockers if you machine down the rocker nuts so they grap 3-4 threads, but it would be better to re-drill the heads for 7/16" studs.
ghettosled
SYTY SUPERSTORE
134-7201
chevy late model vortec (8mm). They are actually .155 taller then the 10mm ones which will help when using full roller or aluminum bodied rockers.
