How are you wiring up the second pump?
I thinking of leaving the stock wiring on the one pump and use racetronix harness with a hobbs switch to turn on the second pump.
Is anything worng with this idea?
What psi should the second pump turn on at? I am thinking 7psi.
How to get the second pump wiring into the tank and still have the stock wiring alone?
http://www.racetronix.biz/itemdesc.asp?ic=FPWH-011&eq=&Tp=
hobbs switch here.
http://www.racetronix.biz/Itemdesc.asp?ic=HPS-7&eq=&Tp=
hobbs switch here.
