killa66cam
RIDIN DIRTY
Re: Dynoed my Sy again.
What converter are you planning on using with the 14 cm housing...2800? How would a converter around 2300-2500 stall speed do with a 14 cm? Thanks.
Cam
Thanks guys.
The turbo does spool up a bit slower than a stock turbo, but when it starts grabbing boost, the boost comes in way faster.
In neutral I can floor it & by 4800 RPM I am seeing 5-6 psi of boost.
If I put on my 10 CM turbine housing, it spools up like a stocker. But it is too restrictive w/a 10 CM.
Eventually I want to use my 14 CM housing, but after I get a better torque converter.
Cam
