Re: E85 on stock fuel lines.
all very correct, Ive also read a bunch on it hopeing to switch our GN to it soon. Got a couple questions tho, herd that GM sensor is expensive how much that run you? and do you still use your wideband in reading reg a/f, or did you switch to lambda? thought i rem reading somewhere lambda was more accurate when using ethanol, your opinion..?
I had Dave Henninger help set mine up. He's one of the top tuners out there for this stuff. (Good enough to be the tuner Robbie Gordon's Dukar team). He chose to use the AF tuning vs lamda on my setup. It may be because of how the FAST FXI system handles the flex fuel tables. When I am using true E85 my AF idle tables are in the 8.8 to 9.3 range which is similar to 13,8 to 14.2 for pump gas. At wot I am in the low to mid 7's vs mid 11s for pump gas. If I put in pump gas my AF table read normal. I use the FAST FXI wideband setup.
Regarding Lambda. It is no nore or no less accurate. It is a scale of numbers that makes it easier to follow. Lambda =1 vs Gas stioch of 14.7 AFR. Lambda =1 vs (true) E85 af of stioch at 9.67 AFR. You have to have a way to set a your computer to know the stioch value of fuel you are using then Lambda can be set to 1 for that fuel.
Here are some definitions that may help...
AFR
The Air fuel ratio is the most common reference term used for mixtures in internal combustion engines.
It is the ratio between the mass of air and the mass of fuel in the fuel-air mix at any given moment.
For pure octane the stoichiometric mixture is approximately 14.7:1 or λ of 1.00 exactly.
In naturally aspirated engines powered by octane, maximum power is frequently reached at AFRs ranging from 12.5 - 13.3:1 or λ of 0.850 - 0.901.
FAR
Fuel Air ratio is commonly used in the gas turbine industry as well as in government studies of internal combustion engine and refers to the ratio of fuel to the air, it is 1/AFR.
Lambda
Most practical AFR devices actually measure the amount of residual oxygen (for lean mixes) or unburnt hydrocarbons (for rich mixtures) in the exhaust gas. Lambda (λ) is the ratio of actual AFR to stoichiometry for a given mixture. Lambda of 1.0 is at stoichiometry, rich mixtures are less than 1.0, and lean mixtures are greater than 1.0.
There is a direct relationship between lambda and AFR. To calculate AFR from a given lambda, multiply the measured lambda by the stoichiometric AFR for that fuel. Alternatively, to recover lambda from an AFR, divide AFR by the stoichiometric AFR for that fuel.
Because the composition of common fuels varies seasonally, and because many modern vehicles can handle different fuels, when tuning, it makes more sense to talk about lambda values rather than AFR, provided Lambda is set for the correct stoichiometric AFR for that fuel.
John
