eDist with Accel DFI distributor: Does it work?
JayLo
Sir Boost-a-Lot
Alright,
I read a couple dozen threads regarding using FAST?s eDist box for firing LS1 coils, effectively eliminating the hassle of dealing with a cap/rotor system. I?d like to do this, but the more I read, the more confused I am.
Will this system work with Accel DFI distributor #77151?
That unit provides both cam and crank signals. I don?t want to mess with a crank trigger or modding another distributor.
If so, are their any other potential snags a guy might run into when doing the conversion using these components?
What parts will I need?
Here is my parts list as I understand it now:
1 - FAST eDist
1 - Accel DFI Dual Sync #77151
6 - LS1 Coils
6 - Custom plug wires
I understand there will be other miscellaneous stuff like brackets, wiring and such, but are there any other major components I missed?
I?ve seen a write up using the crank trigger. Has anyone done one using an Accel dual sync distributor?
Thanks for the help.
________
Medical marijuana dispensaries near dillon montana
warmpancakes
Re: eDist with Accel DFI distributor: Does it work?
The fats edist box is a Cacillac Northstar coil control modul redecalled, yes its possible and its been done I have some notes somewhere when we played with it Ill try to find them. I havent seen them in 2 years
canadian
sy in progress
so is it possible to do DIS with the cadillac box as well?
JayLo
Sir Boost-a-Lot
That would be great if you could find your notes.
How does an edist box from an 8 cylinder work on a 6? Are there any tricks to using a Caddy one over a FAST box?
________
Marijuana Vaporizing
warmpancakes
Nope same box same pin out, if you can wait DFI has a plug and play box to do coil on plug you can even run a carb with it.
