QUICK STORM
B.A.M.F. BMW Tech
Re: egt delete...high iats?
i believe it goes open, although looking at the upper/lower intake if you use the block off plate you definately need to tap that port to blockoff the charge.
LandryPoole said:If you just disconnect the vaccum lines that operate the egr and block them off, does this leave the egr valve closed or open? Does it then act like a block off plate or not? J/C
