EGT tuning?
sy112
I have an EGT gauge on my pod right now that is not in use. Was trying to find a good gauge to replace it but now I am interested in actually figuring out how to use it for tuning purposes.
Lets see if I get this straight, by measuring the EGT you can tell if a cylinder is running rich or lean, cool or hot respectively. So basically you would want to tune for zero knock and then try to get the egt as hot as possbile before kncok started coming back into the picture? basciallly leaning it out as much as you can.
I have done a search and it seems most believe if you are running only one sensor it would be best in the #1 cylinder exhaust manifold, cause of our intake design that is the one that USUALLY runs lean first. Has there been any change in this theory?
this all fascinates me cause I have read that the EGT is more accurate than the stock O2 sensor(as far as rich/lean conditions) and I figure since I already have an EGT might as well use that :wink:
Any input from anyone running or anyone who has run EGT in the past would be greatly appreciated. I know WBO2 is the way to go, more accurate than both stock O2 and EGT but that is still in the works. This tuning stuff gets better everyday, I'm eating this shit up :D Now if I could just apply all this new found knowledge :-?
jwaller
Evil Genius/SyTy Guru
EGT's are a very good tool to use and many times it's nessassery to have both a WB and an EGT. I know I can have a 19.9 AFR but still not max ou thte EGT.
when tuning with an egt you want to get it around 1350-1500 I know thats a wide range but their are many factors that will make an egt reading good on your truck but bad on another. it's an experiment in frustration. egt's are normally slow to respond and thats why I use the WB more. but it's still a great tool esp when you have a 2step and you dont want to melt the valves out of your heads.
Windedv6
Ty n 10s
John
It will depend where you tap your sensor....I run mine into the exhaust housing (before the wheel). Most of my GN friends have their's in the same location. My temps run around 1650 at a 12.0 afr. I know some GN guys that the main tuning is with an EGT. They run them at 1700 and adjust the fuel accordingly. One runs 35# boost with a 10.5 AFR and 1700 degrees. Runs mid nines.
John
Tooky
Serious about performance
When I tune I like to drive around and stuff it through 2nd gear from about 2800 to 4500 and then let off around 55-60mph in the start of 3rd. Is that going to be sufficient to get an EGT reading or is it the kind of thing you need to do a full quarter mile pass and then look at it at the top of 3rd gear? I never used an EGT gauge but I always got this impression they respond really slowly. I know the Turbo Dodge 4 cylinder guys seem to use them religiously.
