Electric water pump
fast_fiero
1st engine on progress...
Has any one run their syty with a electric water pump ?
I find this Australian unit specially interested http://www.daviescraig.com.au/documents/EWP/EWP110_Brochure.pdf
Running it with controller that allows you to remove termostat and only run with needed pumping power sounds like a perfect choice.
Look also this: http://www.daviescraig.com.au/main/display.asp?pid=44
Since I'm going to install a syty engine to Fiero I'm a bit affraid of cooling problems. Engine behind seats and radiator in front requires much from water pump.....
Loeryder
Re: Electric water pump
Nice.
You will be the 2nd Fiero SyTy transplant.
Look up user vortecfiero he built his own headers and made LOTS of custom parts to make it all work.
There should be lots of his posts in the SyTy conversions forum.
fast_fiero
Thanks for the note !
I've noticed Vortch fiero already and I've seen lots of pictures of his car and engine. I try to do as nice work as he has done.
