nallj92
ok, its time to decide what goes in first,
the engine is on the stand painted and ready to drop, the tranny is ready to go too, i have installed the front diff, centerlink, idler, pittman, and new steering box.
( quick tip on the steering "rag" joint slop, i went to the junkyard bought a $15 u joint off a astro van steering shaft, cut and welded to the original, works perfect, cheaper than the $100 GP and thers always more of them too.)
the front clip is off so its pretty open.(no fenders core support, inner fenders, etc.)
what should go in first? i was thinking of putting all the engine bracketry on the engine before going in, including the plugs wires, manifolds crossover, oil coolers PS pump and lines, turbo lines, and lower intake. I would like to install the engine trans in as a combo i have the cherry picker and enough jack stands to lift a 18 wheeler. then once in install the transfer case. and so on.
this is the tenative plan, im not in a hurry to drop it so i want to do it right, i have the red ty im driving now,
any tips or tricks would be great,
I can see the light at the end of the tunnel now!
TIA
justin
TIA
justin
