EPROM emulator program mentioned earlier......
PPI Typhoon
DIY Madman
I'm trying to remember what program someone on the list has used in the past. It allows for changes on the fly via a laptop computer emulating an aftermarket chip.
Any help would be greatly appreciated.
Thanks,
JoeLutz
leroy,
How did you hook up the emulator to the memcal?
If the emulator is installed and the ignition switch is left off for a long time, long enough to run down the batt backup will the program on the emulator be lost?
Thanks!
leroy
I removed the eprom from the memcal and soldered a socket in. You could also use a piggyback adapter, like hypertech uses.
I have left the emulator hooked up for months at a time without program loss. It does not need to stay hooked to the computer.
If you have more questions, you might email me. I don't always keep up with the UBB stuff.
Jim
leroy@sunflower.com
