Re: Erratic Idle On Cold Start
Looked in the manual and did some research on the EGR Valve. It is supposed to pretty much stay closed and only opens during closed loop and mainly freeway driving. I started my truck and my EGR valve instantly opened. I pulled off the vacuum line, letting the EGR close, and the idle kicked up like it is supposed to and started running good. I hooked up the vacuum line again and it started running like crap. After it warmed up, the EGR valve closed, like it should have been the whole time.
I don't have time to order parts, so I am going to disconnect the EGR valve so it won't run like crap on a cold start. This should help when I go to ship the truck back to the states. As long as I don't hot rod it around, I shouldn't have any issues... correct?
Other than a CEL, am I better off installed an EGR delete plate I have laying around from my TPI car? Or should I just disconnect it and leave it?
