Excited!
Well.... EGR has been deleted... the vac lines have all been re-done... Installed new 43# injectors, installing the LC-1, gauge etc. tonight. We shall see where this goes! Got a new HKS SSQV BOV to rig up as well. Pics to follow! Thanks to all that have helped with this in any and every way!
escofield
Re: Excited!
:tup:
tydye
Banned
Re: Excited!
nice, good to see people get hyped up!
bezerk
Re: Excited!
dunno how experienced you are with these trucks but you know that #43 injectors are to big to run of the stock chip?
Re: Excited!
Oh yeah that's with any fuel injected car... You have to turn the base pulse down in most cases due to the larger injector size and then tune for the extra fuel as needed to maintain a solid AFR.
Re: Excited!
My 40lb BIN over on Code59 will be a place to start, although it will need a bunch of work for the 43's... I think we could have you up and running with it in a short amount of time.
I have given a look at that bin actually... I've been working with the $58 bin and xdf thus far as I don't have the Lambda hooked up for $59 YET... but that's all about to change as well! I'm probably going to setup my own for this one from scratch as I'm running somewhat of a "frankenstein" setup. Will let ya know how it goes and post my results to code59.org though!
Brassmonkey
Cruzin' Mel Man
Re: Excited!
Just curious. If you have all that tuning capability, why only 43# injectors? I thought bigger is better in that department. Unless, of course, you like changing out injectors for a hobby. :rotf:
Re: Excited!
We're 5280 feet above sea level here so even though we do make boost it's still a lower map than you see across most the us... Plus it's just a cruiser, not trying to push it to that point... *yet* :D
