F30 table??
myclone
Being a noob and trying to get a handle on how all the tables work/interact I have a few questions on the VE tables that hopefully will tell me if Im going in the right direction or Im just a tard who should stick to carbs..
After 4k RPM (end of F29 table) is fueling based on the values in the F30 table alone? Discounting any other tables for simplicities sake here. ;)
If the above is true then below 4k RPM would both F29 and F30 be used togeather at the same time to calculate fueling?
Last one.. if the above is true then from idle to 1.6K RPM would all three tables (F29,F29E,F30) be used togeather at the same time?
TIA..
(remember.. Im taking baby steps here so try to contain your laughter... ;) )
jwaller
Evil Genius/SyTy Guru
damn it dave read the friggin stuff before you ask a question... 8) go to the chitown site....most of your questions can be answered there....if not look up the P4 document and that lays out everything. and no there are thing like AE, PE and other things that can add fuel / timing >4k.
myclone
Umm.. I did. Thats why Im asking. :-? You think an old school carb/V8 guy just knows what to ask questions about in the first place?????? :p
You talking about here? http://www.chitownsyty.com/bg/chip_tables.htm If so then to say Ive been there reading/printing out info would be an understatement.
P4 document?? You talking about this??? ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227749/Turbo_P4_Doc.pdf Just so happens I printed out all 100+ pages, thank you very much. Im going through it also.
Understood.. I shoulda explained a little better what I was asking as I am just looking at only the tables that I mentioned (29,29E,30) to try and get a rudementary understanding of how things work. Basically Im trying to understand small portions of the program so I might have some chance of it all coming togeather in my head later.
You also gotta keep in mind that your talking to someone who could get lost in his own PC in a matter of minutes. Hell, as far as Im concerned me learning how to post pics on this board is a MAJOR accomplishment.
myclone
smeagol said:
http://www.chitownsyty.com/bg/chipping.htm
Has some info for you. See the tables section, download the document and read it.
LOL.. I was typing as you posted this. I printed it off and have read through it and the P4 doc several times. Needless to say it went WAY over my head at first but I came up with the orig post/questions from looking at that info...
Trust me.. I got all the info laying out on the kitchen table to go over again today while waiting on the guy to deliver 12 tons of gravel I gotta put on the drive way.
smeagol
K, just making sure you ain't trying to piece together your info straight from reading Promgrammer tables, since you'd go insane ;)
VE is done really confusing.
Basically you have a one line table (F30) that is used ALL THE TIME. It is based solely on RPM. It does a lookup for that table, and stores it as VE. Then it does a check to see if the throttle is open or closed.
-If open, it uses the F29 (E?) table for open throttle, and does a lookup based on RPM and MAP, then it adds that VE value to the F30 value, and that is your total VE value.
OR (not both, one or the other)
-If closed, it uses the other F29 table for closed throttle, and does a lookup based on RPM and MAP, then it adds that VE to the F30 value, and that is the total VE value.
It is easier (IMO) to think of the closed throttle table as your idle fueling table, and the other table as the regular VE table. Remember that the F29 tables are only in vacuum. For boost, you'll have to tune the last line of the F29 VE table (highest MAP), the F30 VE table, F77 (base boost multiplier), and the PE AFR table.
myclone
-If open, it uses the F29 table for open throttle, and does a lookup based on RPM and MAP, then it adds that VE value to the F30 value, and that is your total VE value.
-If closed, it uses the F29 table for closed throttle, and does a lookup based on RPM and MAP, then it adds that VE to the F30 value, and that is the total VE value.
THANKS!! Believe it or not thats how I understood it but I wasnt sure if I was on the right track or not..
Whoo hoo Ive only read the P4 thingy a ~dozen time and this http://www.chitownsyty.com/bg/chip_tables.htm about 20 times and have managed to stumble into a correct assumption.. Dumb luck or smarts?? Dunno but I'll take it. :D
jwaller
I want meaning to be rude to ya dave I actually have some stuff at home I'd like to send to ya. buy I'm not home right now and it will be tomorrow before I get home so I'll send it then. I think it will help clear a lot of the questioins you have.
myclone
I didnt think you were being rude myself.. Im asking very basic questions that are second nature to some but a complete mystery to others so I expect to get some ribbing/grief/laughed at quite a bit.. Besides, its not like Ive ever given you grief for various reasons :wink: :D
Send the stuff my way as I'll take all the info I can get...
TIA
