Failed emmision, running rich
I failed emmission yesterday, My truck runs rich under throttle (not at idle). I have to have my truck emmission tested ever other year, I missed the 2003 emmission test, so I haven't had this done since 2001.
I found out for what ever reason my diacom is not reading my BLM (long term) properly. It actually used to be able read the BLM when first bought it (I probably had the 2 bar chip in it.) When went to scan my truck with datamaster the closed throttle is 123 the open 150, which means it is richening my fuel mixture with the throttle open. My Fuel presuure is 43 psi. My O2 sensor moves back and forth properly and is relatively new, its only has had 5 gallon of leaded race fuel through it, never any TEC (I have another o2 for that). Maybe 25 gallons of Xylene but that is not supose to be an issue. My coolant temperature was set for 200 degree (electric fans), so make sure its not a being too cold issue.
I actually had the 150 BLM issue when I first bought my truck, I thought it went away with replacement of parts, aparently I didn't realize it was happening.
I hoping to have my Wide Band install next week.
I am not really sure why its doing this. I wonder if this is an issue that is related to my knock. Nothing looks out of whack for my diacom files. Any ideas?
Re: Failed emmision, running rich
Another Issue I have notice is my plugs don't all look the same. Some have small black specs on the electrode, others look 100% fine.
I have a 160 but I have eletric fans. I set the temperature was set for 195-200 degree for the emmision test.
BigBadSmoosh
drop fp and put in gas line anti-freeze.. helped me pass.. but my truck could barely idle.
This is off the subject but the inspection station pissed me off. As usual I told to take of my truck and be careful. The guy who I did this was nice enough to follow my request but the other two idiots didn't.
I told the one guy up front it was AWD, so it can't go on the Dyno. Ofcourse the other drones had stupid discusion about it. At first he said it was 2wd. After they looked under it and looked up the VIN the realized it was AWD. The other idiot who claim to know S-10's said it has to be switchable to 2wd. He ask me what happened with the lever? Meanwhile while this is all happening the first guy (who I originally talked to) was on the emmision computer telling him it said it was fulltime AWD. It took him 3 or 4 times before they listened to him.
I have to yell at one guy for smoking in my truck. He was just getting the hood release but I told I don't want any burns or the smells in my truck. He was eventually the same drone who held the RPM at 2500. (This what they do in MA when you AWD instead of Dyno) Fortunately he didn't smoke while doing that.
Another guy was laying on my engine compartment over my drivers fender, his head was over by my Intercooler. I came in yelled at him, What are you doing told, be careful of the paint. He said he had to do it because he couldn't find my battery. He said checking the battery for safety imspection. I showed him the battery under the bed, he said he couldn't test me because it wasn't legal. I was BS their are no law to outlaw relocating batteries. I told him it NHRA and IHRA legal and I researched state laws, it had to be vented (if in the interior) and securely bolted down. I lied about research the state laws, but I am pretty sure what I have will pass any state inspection. He seem satisfied with that explaination.
leroy
Do you have diacom and datamaster? Diacom won't read BLM and datamaster will?
It sounds like your chip needs a little tweaking. You can pull your ecm-b fuse to reset the computer just before the test. That should reset the blm to 128 and reduce the open throttle fueling. Can you burn chips?
Of course you still may need a new cat, tuneup, fresh oil, and the usual pre-emission stuff.
HTH,
Jim
Yeah I have Diacom and I have a Datamster cable and evaulation version of Datamaster (17 runs left) I am trying to get Tuner Pro to work for scanning, so I don't want to buy a copy of datamaster. I don't need to buy 3 scan tools :)
Yeah I can burn chips. It seems as though if I can get it into open loop fueling I can force it to run leaner for open throttle operation. I really want to get my WB o2 hooked up and working so I can have a look at what going before I go about this. I wonder if this is related to my knock issue, It really puzzles me that the O2 sensor still goes back on and forth on the scan tool as it is supose to do, but the exhuast smells rich.
I am afraid that reason it run so rich is that i have lean and rich running cylinders...but I am just paranoid about that because that was the issue I had with my Corvette.
Recently cat, tune up 1500 miles ago, oil changed 600 miles ago. I am not too worried about the emission sticker itself, my rejection sticker expires November 19 and if I wait til next year it will just be saftey only. I take my Sy off the road every winter anyways.
BigBadSmoosh
fyi, when i went to inspection with my typhoon the same thing happened.. first woman didn't believe me it was awd.. I had to get into an argument with her and ended up talking to a manager.. of course i ended up failing hydrocarbons anyway..
nj does a 2500 rpm test for 2-3 min..
the 3rd time I went back, FP was at 25lbs, and there was 1/2 a tank of 93 octane, and 2-3 bottles of gas line anti-freeze.. the truck blew white smoke (it was in the midst of winter) but the guy testing it knew what it was.. challenged me to a race against his charger and passed me with flying colors..
(I didn't race him due to the fact that he told me his charger runs low 12s)
leroy
You can do a lot of tuning with a narrowband, if you are not trying to tune for wot. I suggest forcing open loop. (I set KO2ATIME to zero.)
Start with idle. Use the closed throttle VE table and keep adjusting the values until you get the integrator close to 128. Repeat it with the truck in drive, and then with the a/c on. An emulator makes this go a lot quicker.
Go to the open throttle VE table next. I suggest making initial adjustments in 1st gear. Drive down the road, trying to hold the rpm at 800, 1200, 1600, 2000, 2400, and 2800. You can go higher if you want, but it's not an area of the VE table that will be used normally. Repeat as necessary to get the integrator close to 128. Now repeat the process in overdrive, focusing on cruising speeds. If you want to leave it in open loop, leave the cruise lean, consistent with minimum throttle opening, for economy. When you are satisfied, you can switch back to closed loop.
You could send your injectors to be flow tested, if you are worried about balance between cylinders. Variations in combustion chambers, pistons, and deck heights can still cause some problems though.
There are only 2 block learn cells, open throttle and closed throttle. So closed loop correction is primitive. You can be lean in some parts of the VE table and rich in others.
HTH,
Jim
jjorgensen52
NHSTE - I'm the only one!
One of the many reasons to live in NH ... because my truck is older than 1996 (pre OBD-2), I don't have to do any emissions testing to pass inspection :lol:
I have one.
My injectors were sent out last year to be cleaned and flow tested.
I forgot about this for normal closed loop operation, I knew that this could be played with to reduce turbo lag, but I didn't think about the reverse. Thanks for the help and it has my brian thinking again, I just have to find a friend to help out with the testing.
leroy
Thank goodness for brian. lol
Jim
I am staring to think one/some of my injectors has gone bad. My truck is seemingly running worse as the days go by. At the time of Emmision test, 43psi of base pressue it wasn't too bad (smell wise) but now its really bad. When I stop and open the door I can smell the when I get out. I dropped my pressure to 39psi and still same thing.
I played with the closed throttle table some, it seemed like the idle like lots of fuel taken out. Some of it maybe due to the electric fans, but it puzzles me why the same setup wasn't rich like this last year.
I had the injector cleaned last year and I have put 1800 miles on the truck since, I wonder if they just missed it or was on the way out at the time of the cleaning, (but it still passed) or maybe the injector cleaner damaged the injectors or even the Xylene. Last year it didn't run this rich at all and it was 100% same setup, execept I was running more fuel pressure (48psi). When I started it up this spring it was rich so I lower the fuel pressure and it seem acceptable.
The only changes over the winter was the suspension and steering. The only thing the may have affected my truck, I bent a brake bracket just after the track. I basically limped it home, add 3/4 tank of new gas and parked it. I had Xylene in my truck at the track. It would have been water down but I probably still had 1.25 gallon of Xylene mixed in the tank. Maybe since gas station is only 0.6 miles away, the injectors would have seen a higher concentration, I also would have driven very consevatively to the gas station given my caliper could slip off under hard braking due to a bent bracket. (I guess writing this post I am starting to convince myself the xylene over the winter could have screw up my injectors...)
