FAST Tranny Computer - Anyone using?
GEN3Typhoon
Anyone have a copy of the FAST tranny computer software.
Obviously the software is useless without the computer and I am considering buying one... I would like to look at the software and see what all can be programmed. The information on the web site is not that great on it.
If there is a demo version of the software that would be great too..
Thanks,
GEN3Typhoon
Well I have decided to go with the computer from HHP.
I have one on the way.. and with Brian's permission will give a full overview of the product, installation and my personal experience with it.
I say with his permission on the product, in case he already has something in the works.
I am quite excited about it.. there are a lot of extra features in it.
More to come....
10secTy
Sy-Ty builder and Tuner
I am using the stock PCM out of a 1993 Sonoma. I wired it into the stock harness. Then I bought the tunnercat software for the bin to program it.
Cheap and simple.
Nolan
GEN3Typhoon
Well.. I understand there are some cheaper alternatives out there.
I want to use something with the extra benefits that it has to offer.. we will see if it is all it is cracked up to be.
I am a gadget nut... I like to play with the high tech stuff... I bought a chip programmer and all I needed to just use the stock ECM too... once I saw a FAST setup.. I had to have one.
I am really impressed with how far everyone is getting with the stock stuff and programming the chips.. it is a lot more work and takes a lot more knowledge to tune with the chip then to use some of the aftermarket stuff. We will see... I am not saying that mine will run better than anyone using a stock ecm or tranny computer.. I just like the high tech gadgets.
What is the number of the tranny ECU you are using? Also, I need a module that goes on the side of the tranny where the cable hooks in.. anyone have a line on one? I will check the local tranny shops in Knoxville.
jwaller
Evil Genius/SyTy Guru
I didn't know E model trannies came out in 93. I thought the first year was 94. is this a canada thing?
Pittman
are you going with a 60E or an 80E??
Ive always wondered if the 80E would work? That tranny gives you overdrive and strength.
GEN3Typhoon
I bought a tranny out a 1998 Bravada... so a 4L60E.. there are a few guys that are using them from what I understand... just wanted to stick with what I know.
Knowing how much I would have into it now.. maybe I just would have gone with an 80E... but I am happy with it so far.
10secTy
Well it all depends what you want. I have looked at the TCI controler and the stock PCM has way more control but that is true for the stock ECM vs FAST. Now for plug and play fun and easy tuning FAST/TCI are what you want. They even sell the piggy back plugs so you will not have to cut any wires. Keep us posted on how your 4L60E works out mine will not me up and running for alittle while yet.
Nolan
Pittman
Has anyone tried the 80E with any success?? Its a tough tranny but I guess it does have more rotational mass. Going to electronic would have some advantages.
GEN3Typhoon
I think Rich Merlino's(?) truck at the Nats was using one wasn't he?
I he is on the list.. I am sure he can comment.. I think he was also using an NP205 transfer case.. for those sweet RWD burnouts.
Nick
UNIsackV6
I'm the only one I know of that has a 4L80e in a truck that runs and is AWD or 4WD for that matter...Hartman's stuff is stout and he can build you a 80e but he will tell you first hand that the 80e is an all out deal, it has more rotating mass, bigger torque convertor etc, which means you better be making some serious TQ and HP if you plan on running fast. My 80e was done by Roadmaster Transmission here in the Chicagoland area and it is laughing at the motor so far, we made 625HP and 700LBs of torque on 10PSI :wink: IMHO you don't need a 80e until you're making 800+lbs of torque and say 800+HP and you want something to last all year or long+. If you want gadgets then they are available. Let me know any specific questions you have and I will do my best to answer them for you....HTH...
Pittman
Thanks
I was wondering who has done it. I know its a tough tranny. I have wiped out a Bowtie overdrive 700r4 and am on a second build of that trans now. It really wasnt the 700's fualt though. I didnt have it "totaly" full of fluid and under a hard run it lost pressure to the 3-4 pack. I have a big pan now and have a solid 240psi throughout a run now.
