Field Service Mode
Vertigo
Addicted to Turbo AWD
I searched yet didn't find anything relating to this even though i'm sure lots of you know about it already.
In Field Service you can do a quick check of the O2 sensor (for those of us lacking scan tools at the moment).
Field Service Mode
For fuel injected engines, a special diagnostic mode is provided to help in oxygen sensor diagnosis. If the diagnostic terminal is grounded with the engine RUNNING, the system will enter field service mode. In this mode the MIL will display whether the engine control system is running in Open Loop or Closed Loop. When running in Closed Loop, the MIL will also display whether the engine is running lean or rich.
In Open Loop operation (during engine and oxygen sensor warm up) the MIL light will flash 2.5 times per second. Once the oxygen sensor is fully warmed and the control module decides that its feedback is reliable, the system will enter Closed Loop operation and the MIL will flash 1 time per second. During Closed Loop operation, if the MIL remains OFF most of the time, then the engine is running lean. If the MIL remains ON most of the time, the engine is running rich. In open loop operation the MIL light will flash 2.5 times per second.
