Fixed My Tach Flutter
Davemc1963
93 Ty Owner
I'm posting this to try and help anyone with this and tell them what I had and what I did to fix it. Its a little drawn out, (yawn) but lets you know what I did.
My original problem didnt start as tach flutter, but I got a severe case of it on the way.
My original problem was slow-ish cranking and slow starting, and below par performance. but with no noticeable tach flutter at this point.
I took the Ty off the road to fix a few things. MSD cap, rotor and plug wires, silicon vacuum hoses and front energy suspension front arm bushes to name a few. It was off the road for several weeks.
The distributor cap was toast, the central carbon brush was non existent, and I noticed rust in and around the reluctor and pick up coil area, so I attempted to clean this up as best I could. Nothing too drastic though. However, I couldn't get it to start after I had finished the work. I eventually fried the starter. Unbeknown to me, the solenoid terminal from the battery wasn't tight and it went up in smoke. New starter fitted, and eventually started but with major tach flutter and running poorly. Sometimes Ok, then it would belch out black smoke and run very rich, then Ok again. Nothing obvious on the diacom, just lean, then rich. At first I thought bloody plug wires, even though I had checked their resistance before fitting them. put old ones back, no difference. Maybe coil or MAP sensor had gone bad after I fried the old starter. But I was still getting a spark. I checked the timing and it seemed to be a bit inconsistant. I was getting pretty desperate at this point, thinking ECU damage again from the fried starter I had also had the ECU out to verify that I had a standard chip fitted. I decided to check the wiring from the ECU, I belled out all the ECU wires to MAP, TP sensor and dissy. All had good continuity. Reseated the Prom. Checked out the pick up coil and module and they all seemed to check out OK. I felt under the distributor reluctor and a small thin piece of cast iron/steel came off in my fingers. The reluctor was actually cracked in three places. The magnet in the shaft was also cracked. I hadn't noticed this! Its not the easiest place to see on these things is it? There was a bit of rust around there though. I dont know if the cracked magnet under the rotor arm would have mattered in the big scheme of things, maybe someone else will know this if you find the same.
I decided on a new MSD billet replacement from summit. I also changed the coil for a new Summit brand one, but I have no reason to believe the coil was to blame. I just fitted it at the same time. It fired right up, Tach flutter down to just a small flicker. I then cleaned and remade the earths on the rear of the drivers side cylinder head, there are two (14mm spanner). I also ran a couple of extra earths from these, because I believe this to be a problem area. One to the alternator bracket and one direct to the battery. You may not have to do this, I did it for insurance. Hey presto ZERO tach flutter. I was made up. Running again and no tach flutter. So, although I cant be sure if a new distributor is required for all tach flutter problems, or just the earths at the rear of the L/H cyl head. But My distributor reluctor was actually in three pieces. I dont really know the cause of this, but there was a fair bit of rust in there. The engine ran reasonably before, it just went flat at higher rpm. At this time, I have only had the Ty out once, and I have a few more things to sort out, but it is much improved and the tach flutter is gone. On the plus side, the engine now fires up practically immediately. Little to no cranking required.
I realise this is a little long, but I thought it necessary to let you know what I did. I was pulling my hair out searching for posts on what to check for. The stock distributor when out looks like the flimsiest POS you have ever seen compared to the MSD one. At least I can make an oil pump primer out of it!
Oh by the way, to get to the earths, you need to remove the drivers side inner fender.
I hope this helps someone.
supersports10
Re: Fixed My Tach Flutter
great post!!! very informative!!
i have seen this on a s-10 baja also, new distributor fixed it also.
i was going to laugh at the constant "earth's" refrence to negative grounds,
but then i saw that you were from england.......i say....good show old boy...good show!!:tup:
2fast4u
PUMPING THAT IRON!
This is the kind of post i like to see. The remedies to problems. Thanks for writin' it up. I believe my tach flutter could be from the distributor too. Now, Iam almost positive, since it looks kinda rusty in there.. and the magnet/pick up coil directly under the rotor will move back and forth if i move it with my fingers. I dont think this is normal at all. Thanks again! A 5 star post :tup:
2fast4u
PUMPING THAT IRON!
Hey Dave, Would you give me the part # of the distributer you bought from Summit? I'm getting one!. Thanks in advance. :D
Gnocide
turbo game burt reynolds
couple of questions.
how did you check the wires for resistance?
whats the acceptable resistance supposed to be?
i have already changed my distributor and believe my wires are the issue.
good post
SY2932
Administrator
good post
Wire resistance is read with an ohm meter, be it analog (needle style) or digital (LCD display). Some values can be seen here.
DynaGlide
Ton-Eighty
My tach is smooth as silk... pegged at zero for three years and counting. :D
Earth, "bell out", spanner, "bloody". The lady of the house next door is from England, great and fun family.
Davemc1963
93 Ty Owner
Hi Guys, I'm glad someone found the post useful!
Hey supersports10 less of the Hooray Henry stuff please. A good ole Blue collar Northern lad here :lol: No offence taken, only joking.
2fast4u the Part number for the MSD dissy is 8367. $311. Kinda expensive, but seems well made, especially when you compare it to the GM one. You will see what I mean!
http://store.summitracing.com/egnse...S=1&Ntt=msd-8367&searchinresults=false&N=+115
Its literally a straight swap, old one out, new one in with the supplied break in lube on the gear. Dont fit the supplied o-rings unless your block has been modified as per the included instructions that come with it.
Gnocide, as sy2932 posted, you need to use a multimeter set on ohms (low scale) the resistance of any good wire should be close to 0 ohms, (If the meter is an auto scaling one make sure your readings are in ohms NOT Kohms) certainly less than 1 ohm. see the link sy2932 posted. There are always variables, such as different components included in circuits which can affect resistances. relays are a prime example. A proper circuit diagram is a must when checking out problems. And that wont include any mods that someone may have added, such as anti-theft devices spliced into critical circuits, that can cause all sorts of problems. However. to check the circuits I highlighted, you need a Factory manual. Each wire has a number (circuit) and you need to find both ends of a suspect wire (circuit). Connect one end of the multi meter to one end of the wire (sensor end) and the other to the relevent terminal at the ECU. All the ECU terminals are numbered. On my 93 they are connectors C307, A1 - A12 / B1 - B12, connector C310, C1 - C16 / D1 - D16 and connector C311, E1 - E16 / F1 - F16 , C3. These are the three plugs to the ecu as you probably know and have all the ID numbers molded on them, but they are very small and a little difficult to see, but they are there. But dont assume the connector plug schematics order shown on the diagrams to exactly match the order on the connectors on the ecu, they dont! You need to check the terminal pin number to confirm you have the correct wire. There are a several with the same colour wires next to each other. You will need a thin probe to get at the ecu plug wires. Probe from the back (wire) side DO NOT push into the pin socket with ANYTHING or else you will probably damage the connector and then YOU WILL have problems. If you dont have thin probes with your meter, you could probably get away with using a thin wire or even a paperclip attached to crocodile clips, (or is that gator clips for you guys :rotf: ) but whatever you use, make sure it has a sound connection to your test meter and check the resistance of your test leads with whatever you are using before checking the circuit to make sure you have a reference resistance value. It should be very close to zero ohms. When you have found both ends of the circuit you want to check, connect your meter and waggle the wires a little at either end to make sure the resistance doesn't change. If it does, or its intermittant or you dont get repeatable values you should first recheck your meter/test leads and if they are still fine, you have probably found your problem. Some of the connectors are difficult to get into and obtain good contact unless you have the appropriate test probes. Take your time and double check things. Make sure you arn't missing something and you have the both ends of the same wire before jumping to conclusions. Oh and make sure the battery is disconnected before checking out the ECU unless you know what you are checking for.
Oh yes, sorry for using the term EARTH, I meant GROUND as you rightly picked up.
Dave
ranger
My distributor rusts so badly that I have to replace it every other year. I wish I could figure out why. I just keep gettin' up free from Autozone, then sawpping in a Delco Module. Still, I wish someone could tell me why my distributor caps last about 4 months, as well.
--Craig Stangohr
Aiken, SC
sy 1563
