Re: Fuel pressure adjusting
Do you guys set FP with the truck off and fuel pump jumpered and line connected? Or is that wrong?
Normally it would be set with engine running.
I set mine at idle, I think I ended up doing 33psi at idle with the vacuum line connected, I knew that I was doing a completely custom tune, so it really didn't matter. My first tuning experiment which I screwed up so I set it at 30#, because my experience in the past was that some injectors need at 28psi to open properly, so I knew I wanted it higher than that. I up the FP a few psi on my second attempt because I know that I had a lot of lean spot in the upper Rpm the first time around.
If you have already done a bunch of tuning already (most likely in open loop), I wouldn't touch the FP unless it is way off... Changing the FP shifts the all fueling in open loop.
