Fuel Pressure Gauge Installation
MikeRenz
not stock
Re: Fuel Pressure Gauge Installation
a standard handtool fuel pressure gauge will screw right onto it. Dunno what the thread is though.
bjk_typhoon
1993 Typhoon
Something over the counter any a local youkal auto parts store?
MikeRenz
not stock
i bought mine at sears....but yea any should work. Work case is you just return the tool if it doesn't fit.
Quickstop [UK]
Combating adversyty.
so what size is the T fitting going from the metal line to the rubber line? Got a bit sidetracked on this one.... hence the delay.
hatrik8
MikeRenz said:
you can either get a schrader valve adapter and attach it to your fuel rail. If you do it this way you need to remove the pin-nipple in the schrader valve (this requires a special tool that you can get at any auto store for about $4)
Do you have to move anything to access the schrader valve? Do you have to remove the schrader valve to remove the nipple? I have no experience with this at all. Any help would be good. Do you have to release the pressure from the fuel system? Can someone walk through the steps to do this. Is it just remove the pin-nipple and attach the adapter? What do you do with the pin-nipple when you remove it? I have so many questions :lol:
too many toys
IM LOVIN IT
I would be cautious with my trust in the auto meter electric gauge i installed one in my race car and replaced the gauge twice and the sensor 4 times before i gave up and just used it as a really expensive idiot light as the reading was never even close to what i would set it at , at the regulator . not trying to deter you but tobe wary :2cents:
Quickstop [UK]
I got the fuel pressure sensor relocation kit from RPM which seems fine, but I need an adaptor for the hose to the autometer sensor (noted about it not working right, but I bought it a while ago and am stuck!)
What is the thread on the schrader valve? I used calipers and got it at 10.87mm with a 1.25 . That was the number from the thread tool I got but I never used one before and want to make sure I am right.
The calipers were measured on the outside of the thread - sounds like 10mm and 1.25 threads per mm. Sound correct?
They are expensive adaptors here so if anyone can tell me for sure I would appreciate it so I can get it right!
Thanks,
Mark
cvcsmkr
my sy came with an elec autometer with 2' of braided hose to the sender, which was all over the enigine bay and pissed me off.
i cant remember what happened but i called autometer and they sent me their new style for free. the new sender is less than 1".
so i went to my friends shop that has all the AN fittings and hooked the sender right to the schrader valve port, and the total setup stuck off the fuel rail maybe 2" worked out very good.
ty166
any idea who's fitting ,earls, russells, aroquipt he used and a possible part number ? not lazy just tryin to make sure i order the right part.
thanks
ty166
i saw that in another post but couldnt find it on-line anywhere , thanks for the link. my f/p gauge is on its way , is that all ill need to hook it up or will i need another fitting from the schrader valve to the sending unit ?
vortecfiero
you still will need a schrader valve adapter..
Im looking into drilling and taping the correct pipe thread
into the collar as it seems to have enough material there
