Hi. Is it normal that if the engine is running and I stop it, wait couple of minutes and press schrader valve in fuel rail, there's no pressure in rail.? Where is bossibly leak? No external leaks, fuel reg?
Agreed, it should hold for a few minutes. Reasons an be; bad fuel pressure regulator, a leaking fuel inj. (does it miss for a moment when you restart it?), bad check valve in the fuel pump, a leak in the system somewhere.
