typhoonscuba
ok i did search for the correct fuel pressure to set and i just wanted to make sure i was right. vaccum hose off and the truck started fuel pressure should be set at 40 PSI. does it matter if you have any mods on the truck? my typhoon has a crane cam, a 20g turbo. my buddys syclone that im trying to get running better has a stock engine with a 850 cfm turbo, air to air intercooler. i didnt know if i should bump up the fuel pressure because your trucks have bigger turbos or not? thanks in advance
