fuel pressure?
tyfoo
do I set the fuel pressure at 46 at a idle with the hose disconect .
or shut down with the pump running?
tyfoo
the atr afpr when screwed tight only takes me to 38
engine not idleing and vacume off
how would i bring the pressure up?
tyfoo
i lossen the nut and turned the bolt
and i'm up to 42 psi ( not runing and vac disconnected)
theres a slight breakup around 1500 rpm
should i go up to 45-46 or down to 38-40?
also over bossting withe the rod all the way out only holding by a thread
turbodog
Try again with engine running and vacuum disconnected, just to be sure. Could be low voltage to pump. You need to be at 46 PSI.
tyfoo
ok
the directions that atr was wrong and there is an adjustment screw
the manual says to go between 38-40
do I then add 1pound for boost to make it 52 psi if it runs to 14 pounds of boost before cutting out?
GM TURBO
Sell Out
No - the AFPR will adjust with boost. Set it to 43-46 (whatever is best for your situation) and let physics do the rest.
