fuel pump is gone!
QUICK STORM
B.A.M.F. BMW Tech
got out of church today and went out to the ty. fired right up, made a left turn out of the lot and then nothing.
thought at first that is was a dead battery, no, just kept on cranking, even trying to be jump started by a suburban.
pulled spark plug wire, to a screwdriver, held it next to the altenator, had someone bump it, got spark.
then it dawns on me, i can't hear the fuel pump, turn the key on and check for fuel at the rail,nothing squirted out. there you have it, the fuel pump is shot.
had ty towed to dads shop and did some diag. with my dad.
fuse for the pump popped, so we put another fuse in, truck starts up the dies, pops the fuse. checked for fuel pressure with another fuse in, i get 45-48psi(is this normal)then it drops, so i know the pump cant hold pressure and its bad.
now the problem, i want to get a walbro 255, but it won't get to my dads shop in time for me. the ty is my daily driver for know, so i'll settle for an AC DELCO pump for now until i get some more money.
are AC Delco pumps good, getting it cheap thru my dad.
TYRODD
My ass. Look at it.
That was the first thing my typhoon threw at me, I also had to use a Delco pump for the time frame :-? .
QUICK STORM
B.A.M.F. BMW Tech
got to the ty today.
took the 3in. blocks out and put 2in. in.
replaced the fuel pump-ac delco
replaced the fuel filter-ac delco
replaced the oil pressure switch for the fuel pump-ac delco
replaced the cap and rotor-ac delco
got the right spark plugs
got a fuel pressure regulator-ac delco
got a IAC-ac delco
so put in the fuel pump and filter and tried to start up the truck, no go, keeps stalling or cranking or popping the fuel pump fuse. did some diag. called a very reliable source. he said replace the oil pressure switch for the fuel pump. replaced it started up, ran for a little then died. while i was in there i replaced the cap and rotor, thanks to help of my dad and his employee, skip. all of this was done at my dads shop, had access to lifts and all the correct tools for the job.
so the ty is running just not idling so i had to keep it off idle. went to test drive it, so i pull it out and get it out on the road and got behind some traffic and the truck dies on me, so i push it to the side of the road. then i run over to my dads shop and get skip, luclily the truck died about 60ft. from the shop we push it into the shop and sure enough it popped the 10a fuse again so i put a 15a and drove into the shop.
now, we don't have a clue really what to do, but we are pretty sure its a bad IAC, so my dad and skip work on some other cars, while i'm searching frantically on this site for answers. from what iread and what we did were pretty sure its a IAC, so we try again to start the ty, starts right up and then the idle starts hunting like crazy between 300rpm and 1000rpm, check engine light comes on, then goes away after a few minutes, idle is still hunting. once the truck is put in gear it immediatly dies. now were pretty damn sure its the IAC.
cause i work tomorrow, truck is stating at my dads shop and he's going to have i towed over to this guys shop that is a wizard with electrical. hopefully he will not have to do much and he can slap a IAC on and it will run perfectly. thanks to my dad, his friend marcello(wizard) and skip, who worked on it more than me, this problem will get solved. saved tons of money in labor today with their help.
if all goes well i will be putting the plugs in very soon, it has piece of crap spitfires in it right now.
Jimmy
Banned
What code did it throw?You might wanna check the FPR for a cracked diaphram,that would also cause it to not hold pressure.
