Fuel pump question
aasltmike
Wanting to replace my fuel pump soon and question I have is how difficult is it to take the old pumping unit apart from the assembly and replace the old pumping unit with the new one? Not wanting to go with a cheap-y Airtex from Advance or Rockauto but don't wanna risk breaking the assembly taking the old pumping unit apart either.
Static
Re: Fuel pump question
Its not that bad of a job. Hardest part is getting the tank back in and hooked up. I used a walbro pump and a hotwire kit from Racetronix.
aasltmike
I'm good with the whole procedure on replacing the pump. I've replaced a few before. I shoulda clarified my question, I guess. Just wanting to make sure taking the old pumping unit apart from the assembly is straightforward, is all. Anything I should be aware of: possibility of anything breaking when I go to take the old pumping unit apart from the assembly or am I just safer replacing the entire assembly. Haven't found a brand other than Airtex that sells the entire assembly, just finding the pumping units.
Turbotoyz
I haven't done it in years. I recall it was pretty simple. I think there is a plastic cover with some 10mm bolts??? Then a couple straps, fuel lines, a pigtail??? I don't remember, its easy. Just do it when you are low on fuel. Haha
nallj92
if its not rusty, no problem, if not the feed/reutrn lines may bend/break. if you can get the tank angled and get the lines off, the rest shouldnt be a problem.
aasltmike
Found a video that showed an auto tech replacing the pumping unit. Looks pretty easy to replace just the pumping unit. I know the big pain is actually dropping the tank and getting the lines disconnected. Thanks all for the input! :tup:
SY2932
Administrator
Be sure to remove the pulsator if it is still in there and use the correct fuel line to do so. Check out this thread to see why. Also as mentioned above, be sure to use a back up wrench (line wrenches preferred) when removing the fuel sending unit lines. If it is rusty, you will probably need a new lock ring/cam that holds the sending unit into the top of the tank. The GM part number for it is 2512-4032 the chain part stores sell them as well but the OEM ones are better quality. Even though you have a typhoon, the tips here might help you out too.
atkonkler
Is this your bush?
Biggest ordeal I see is getting the lock ring loose without mucking it up. Soak and soak that ring and line connections so when you take them apart you don't twist the lines going to the pump or lines coming out of sending unit. Good luck buddy!
