Re: Good distributor options
In reading about spark plugs, gaps, whatever I often come across the term " ionization." Never quite knowing what that meant I thought it would be germane to the conversation. So I looked it up.
A spark gap consists of an arrangement of two conducting electrodes separated by a gap usually filled with a gas such as air, designed to allow an electric spark to pass between the conductors. When the voltage difference between the conductors exceeds the gap's breakdown voltage, a spark forms, ionizing the gas and drastically reducing its electrical resistance. An electric current then flows until the path of ionized gas is broken or the current reduces below a minimum value called the "holding current". This usually happens when the voltage drops, but in some cases occurs when the heated gas rises, stretching out and then breaking the filament of ionized gas. Usually, the action of ionizing the gas is violent and disruptive, often leading to sound (ranging from a snap for a spark plug to thunder for a lightning discharge), light and heat.
If I still have you the voltage required to exceed the "breakdown" voltage is governed by something called Paschen's law which I also looked up. The simple version:
At higher pressures and gap lengths, the breakdown voltage is approximately proportional to the product of pressure and gap length, and the term Paschen's law is sometimes used to refer to this simpler relation.
IOW the higher the cylinder pressure and/or wider the gap the more voltage it takes.
If you think about this, the topic and opinions stated actually make more sense. IOW we now have the "why" a spark does what it does.
I worked up sweat doing this so I hope it helps.:rotf:
