Had recent valve job on 92 Typhoon heads. Heads were shaved. What type and brand of head gasket is recommended for installation? Any thickness I should consider on the gasket since the heads were shaved? They took off 0.010 on each head. Former owner had 0.002 taken off on a valve job he had done.
Also this motor has had some work in the past. Bored 0.30 over and a mild cam. Should I consider a thicker head gasket that will hold up to the horsepower increase and boost? It looked like a corner of one of the old gaskets was starting to leak. Found out that the head gaskets that were on there are the stock ones. Any suggestions would be appreciated.
