Heater core bypass
asrnj77
..hard to swallow
So I searched every post I could find on the subject and was thinking I could just buy a 3/4-5/8 hose connector, pull the hoses off the heater core and attach. I've read others using plastic 90 degree elbows. If I just get this coupler can I attach and be done with it?
2500avalanche
Well-known member
Re: Heater core bypass
Mine has this done to it. THe guy put a shut off switch for the heater so it can work sometime or when I choose. I know they do this on Semi trucks
If yur bypassing the heater 'cuz of a leak then yes. Otherwise there is no need. In fact, IMHO, it's better with the heater to allow some circulation when cold to avoid hot spots. And in case you're wondering big trucks have bypass type t-stats so heater or no heater it dosen't matter.
asrnj77
..hard to swallow
Yes, it is because of a leak. It will be the temporary fix. I didn't read that I could cause any damage doing this. It seems that some people leave their trucks like this all the time. If there is a better way to do it, I'm all ears. How would I plug them off (assuming this is better)?
Just loop them and be done with it. You can plug the top fitting at the manifold but the one at the rad is more of a hassle.
I've been running a loop (bypassing the heater core) in my '82 S-15 w/ swapped in '90 4.3 for almost 8 years now. I keep putting off replacing the heater core until the dash is off for another reason - just hasn't happened yet. Aggravating not having defog function but no ill effects w/ motor that I can tell. :2cents:
Darin
Do not plug them off! I jsut went through this. It'll cause some serious hot spots and not allow the coolant to circulate when the thermostat is closed. I didn't pull my thermostat to look at it, but I'm guessing there isn't a small hole in them to allow some coolant bypass, it just uses the heater core instead.
My truck went from overheating to running properly with the connection of the heater core. Looping them would be just as effective.
turbodog
I put ball valves in line with mine. I leave them barely cracked open in summer. Reduced flow in the heater (given the 17 yr old rotted gasket on the flapper door that divides the hot air from the A/C) helps the A/C blow cold. Open in the winter so my heat works.
