Help identifying turbo
NJ93TY
A friend of mine has a Syclone but not sure what turbo is on it. Cant make out any numbers on the exhaust side, just the cold side. These are the only pics I have of it now, could get more if necessary.
jpalmer
Re: Help identifying turbo
atr downpipe and waste gate. so, yes it is a pte, maybe 50 something mm?
QuinnSY
I have the same package as you on my truck and what I determined is that ATR sold three different turbo packages including the Downpipe, wastegate, and the turbo. The turbo seems to be a Garrett T3T4 setup. The only difference I can see between yours and mine is that on your housing it says "A/R 50 M24" of where mine says "A/R 60 M24"
I thinK this is the ATR Catalog that has the turbo, Downpipe, and wastegate
http://www.syty.net/forums/showthread.php?t=79954&highlight=atr+catalog
I only have pictures of my turbo, and I dont believe I have any from when it was installed on the truck, but mine looked identical to yours except I had the 90 degree inlet elbow going into an ATR cold air box, and mine was Air to Water intercooled
NJ93TY
Thanks for the replies guys, I thought the exhaust housing looked like a PTE cause I used to have a PTE-52 and it looked similar.
Tony Dipatri
I have a similiar turbo on my Syclone. I tryed to get mine identified but had no luck. Does it have a 3 bolt pattern with a a 4 bolt adapter?
Raist103
imo ^^^ is correct atr package.
