Help?? Miss at operating temp.
OK, after an hour or so of searches I've decided to ASK for opinions both here and on the "S" board.
First of all, I have SoGT#549 on the road again but I have a new issue. I've got the other issues solved and when I fire up my truck it rust absolutely beautiful. I go out for a test drive and as it warm up it developes a miss or sputter. It's intermittent at first but once at operating temp it is fairly regular. It sorta acts like clogged EGR or leaking CPI unit but I am sure that's not the case. The CPI and Nut-kit are new and the EGR has been eliminated via custom chip in the ECM. I tried using the stock chip again but the issues are the same.
I've had the base timing advanced anywhere from 2* to 6* and never noticed the problem. Now that I have everything fixed I set it back to 0* where it belongs and re-set the ECM. No codes so I'm thinking great! But, as mentioned before it developes a miss at operating temp so I believe something is either retarding the timing, incorrectly adjusting the fuel or I have a plug wire issue.
My first instinct is the O2 sensor since it doesn't even operate at low temps. (correct me if I'm wrong). Second I'm thinking I have a plug wire arcing somewhere but why only when hot? I thought about a knock sensor but it seems unlikely.
Any ideas guys? Does heat affect timing? I only ask this because I never had this issue with advanced base timing. Has anyone ever had issues like this before? Tuesday is race day and I hope to have it running up to par.
Thanks in advance
Re: Help?? Miss at operating temp.
well definatly check the plug wires to make sure there not arching on those headers yo got, and also go ahead and check the resistance of all the plug wires as well to make sure they are all pretty close to the same and you dont have one with excessivly high reading.
Also check to make sure the rubber plug that is around the CPI wires is tight and not leaking air, ive heard fo those getting dried out and they produce a vacuum leak and all you do is put some clear silicon over it and it should clear it up.
Also i would go ahead and remove the IMTV and take a look and make sure the regulator or any of the injectors arent leaking, just becaue they are new doesnt mean thay are good.
Also check your fuel pressure when its missing, your fuel pump might be trying to go out on you when it gets hot. Check voltage to the pump when the truck is up to temp and the miss is there, could be a relay getting hot and trying fail.
If you dont find the problem in all of that, there is also the ignition module, i had a similair problem on a buick FWD car with a 3.3 V6 and chased the problem for over a week and i had the module tested 3 times and it passed every time, no matter how long you tested it and no matter how hot it got on the bench, it woudlnt fail, but a few hours in the car and bam either it would miss or wouldnt start. Replaced it and never had the problem again.
Hope this helps
Mike
I might add cap and rotor failing under heat stress. Since it comes on slow look for something that takes awhile to get hot. Another item might be the coil itself. Had one just flat fail the other day on a company truck.
Good luck.
Thanks guys, I think I am going to replace the coil then it'll all be new.
I also noticed one of the plug wires very close to the header so that
may be the problem as well. Doesn't appear to be damaged but it's
definately too close.
