Sy#1991
I have a popping/knocking noise on steady cruise under no boost. As soon as I am into boost it goes away. If I blip the throttle or find a steady rpm the noise is very apparent. I was listening around with a stethoscope and it almost sounds turbo related. The shaft does have slight up and down play but the blades on both sides look good (I removed the o2 and bore scoped the exhaust side). The blades are straight and have no bends or chips in it. All help and info is greatly appreciated thanks.
