how do I lean it out?
jwaller
Evil Genius/SyTy Guru
leaning under boost.....ok...this may sound dumb. but I'm having a problem with being able to lean my motor out under boost. I've worked with the PE AFR table. and I've leaned out the F30 table but how do I change my fueling at 4400rpms @15 psi compared to 4400rpm's at 10psi. I'm just not seeing it. the F1 table has tha good resolution for this but thats spark. I cant find that kind of table for fueling.
10secTy
Sy-Ty builder and Tuner
Yep Jim hit the nail on the head. I use that table to be lean in the 1-10 psi for street. and 1-16 psi race. This helps Tony make the 16psi on the line :D
But be carefull you can go to lean :(
Remember 1st gear will tolerate alot or timing and lean AF due to the less load. But make sure it is all back to normal for the 1-2 shift.
Nolan
jwaller
thanks guys. this is what BG said too. I havent used that table much yet, I ad been using the F30 mostly. and I couldnt get what I needed with that. this should do it.
