Turbo6
10.20@131.8
You need to make a few passes and experiment to see what rpm works best with the 2step. My best 60' was a 1.58 launching at 3100 and that gives me about 9-10 psi without any retard. The last 12 passes I have made the 60' has been between 1.58 and 1.64 I believe. The only traction problems I was fighting was when the boost would shoot up to 22 in 1st gear and spin the tires hard. Fixed that with a 2 stage boost control running 16-17 psi in 1st gear then flip the switch to go to 22 when it hits 2nd. I think the main things keeping my trans alive is letting it cool down at least 30 mins between runs and keeping the fluid fresh with either type F or trick shift.
Les the weather forecast is for mid 60's and partly cloudy but that could change 12 times before Sat
