I could use some help
tbauer03
TRBOBOX
Ok i am not sure exactly what happend, but about 10 o'clock at night (30 minutes ago) i just put on my new zr1 wheels and got them balanced and everything. (I love the Wheels) anyway i wanted to see how smooth they were and how balanced they were so i got on the highway and took her up to 70 all good, then to 90 all good, then to 100 all good, i was impressed how smooth it was so i figured why not hit the 120 mark, so went up to 120, and still smooth, got scary real quick so i slowed down and got off the highway and when i came to a stop my engine stumbled and died. Then i smelt oil burning. popped the hood and saw my oil dipstick blew off and oil was spewed out on the turbo etc, which is what i smelt, but there was some smoke coming out of the dipstick. I rolled it into the gas station and let it sit for a while while i tried to analyze what just happend. I started the motor up and it idled a little rough and oil pressure was about 40 I put it in gear and oil pressure dropped a little briefly then came up to about 60, engine temps were good probably 180ish, i let it idle for a while and it was not making any loud noise but exhaust was smoking white smoke. i tried driving and then it wanted to run rougher and kinda like it was misfiring a cylinder or something, the exhaust smoking quite a bit and i limped home about 3 miles, basically rolling, if i had to go up a hill it would run worse. got it home and the exhaust smelled funny and was still smoking. Turned it off and came inside to post it.
I am thinking it could be a blown head gasket or fouled plugs or really anything else for that matter.
What do you guys think it is, what do i need to do. any input here is greatly appreciated
Sy769
Excessive blow by can blow out the dipstick and the pcv valves.
Sounds like you might have popped a head gasket or broke a ring.
I'd do a compression test and take a look at the plugs.
If you blew a head gasket it will probably push water out of the radiator or get water in the oil.
tbauer03
TRBOBOX
i checked the raditator the fluid level is good and i noticed no bubbles in it. I will check the oil and spark plugs tommorrow when i can see more stuff in the daylight.
TurboManiacal
If you don't fix the head gasket now before it's started/moved again, it could cost you a new motor (I speak from experience)
sy112
hate to hear it Ted.............. :(
good luck and hopefully it turns out to be an easy fix, or at least no excessive damage
tbauer03
TRBOBOX
Yeah hopefully nothing too extreme has happend yet to where i need to replace the whole motor. It is not going to be moving far at all. This is why i am still paying insurance on my blazer.
tbauer03
TRBOBOX
Well Jim came over and we took the spark plugs out and and they were all covered in oil and did a compression check and came up with nothing coming out of the #1 cylinder. So we concluded a broken #1 piston.
I am now accepting donations to help me get this thing back on the road. :D
Anyway it looks like a good time to make this thing go fast i just need to drop out of school and start working. :-? nah i think i am going to need to stay in school and plan a rebuild this summer.
bezerk
I would drop out of school, SyTy's are more important than education!!!
Just kidding,
Really sorry to hear you are in this situation, it sucks!
Good luck!
DanenGraham
Big in the rear
WTF, first Zach now you. Good god been a sad few months in the SyTy world.
Hell, if you need help on it this summer, i will be around. Or just call jim and he will do it all for you :wink:
and to think you were just running 13.3's almost all stock.
Sy769
Same thing I found on the wife's Ty. #1 cylinder had virtually no ring lands left
Ty 1450
30psi on 93 oct (boom)
120 pfft i think Patrick has me going 135 on dm one day (and i didnt get pulled over which is really rare for me :x )
tbauer03
TRBOBOX
Here is what i found.
Picture Quality Sucks
It left a pretty bad mark and it is deep (the pic doesn't show the cylinder wall damage very well but you can see where the piston broke) i am not sure if it will bore out or not. i hope so.
92BlkTy
BOWTIE BLOCK!!! :lol: that sucks ass ted. i think mine is on its way out too. im guessing ive got a bad bearing because it knocks at idle. but just a idle. :x i guess now your officialy a SyTy owner. i hope i never get initiated in. :cry:
let us know your plans. motor/turbo etc. this is just an excuse to spend money and go faster. :wink:
Ty 1450
Dam Ted that sucks...hope you have it running by nats (if not we could use your motor for some kind of event called "fix this sheit")
DanenGraham
Big in the rear
tbauer03 said:
DanenGraham said:
Dude, u already got the motor out. thats some fast workin.
Yeah my hats off to Jim Sloan he makes everything possible.
I knew you had some help. :wink: Jim is a mad man when it comes to working on things from what i have seen.
