psmvchaser
OK, I wired in my innovative wbo2 into my ecm. The afr in datamaster now matches the innovative display. This seems to be working properly.
The problem is that ever since I have messed with the ecm wiring, there is a drain on the battery. It gets to the point that it will actually stall. I took the alternator and had it tested (good) and my battery is new. The other symptoms are that upon starting the Ty, the speedo instantly goes up to 50 mph then comes down. I just drove it and no matter what speed I was going, it showed 60 mph. Also the tach is buried all the way to the stocl boost gauge. Another wierd thing I noticed is a whirring noise that seems to be coming from the alternator area.
I am hoping all of this is related and can be cured in 1 step. (yeah right) I don't know if its a ground problem or that I just wired something wrong, but I double checked everything and the wbo2 works right.
Please help if you have any ideas.
Ken
Ken
