IAC and High Idle
Well, I have been fighting with my SY for a couple weeks now because of a high 2K idle issue. If you want to skip the story go to the bottom for my question.
At first it was a couple small vacuum leaks. I got them all plugged and it seemed to work. I installed my vac/boost gauge and stock solenoid and the problem came back. I thought I damaged a vac line so i replaced them all. No help.
With help from the board I checked the TPS. When I removed it and replaced it the problem went away again but soon returned when I took it out for it's maiden "hard" run.
Pinching off the PCV hose helped quite a bit but it still idled at 1K or so. I found the IAC was only finger tight and I removed it by hand. i figure this is where my vacuum leak is. I tightened it up. Now it's idleing faster about 1200.
Question....
Does anyone know how to properly adjust the IAC? The tip is on a threaded rod with a spring. Should I just buy new and forget it?
I compressed the spring and turned the tip a couple revolutions.
1st attempt caused NO IDLE at all. It runs fine but dies at 0 throttle
2nd attempt it idled much better and I drove it this way for a day or so.
3rd attempt I think I have it zero'd in better since it idles at about 750-800 now.
I haven't driven any long distance or gotten into boost but it seems much better than it ever has. I think my initial problem was a combination of everything I mentioned above but I'd really like to get this thing back to it's proper adjustment.
mmp142965
say it like you spell it!
Re: IAC and High Idle
I have an almost new IAC with 2K miles on it if you want to try that; I know it works. I just rebuilt the throttle body because of idle/IAC issues. The gaskets where as hard as plastic and crumbled apart. The entire gasket kit was 6 dollars at autozone, and the truck runs much better after that. :2cents: let me know if you want to try the iac.
jjorgensen52
NHSTE - I'm the only one!
there is an automatic adjustment methood I used on my Ty, but I can't remember for the life of me which terminals it was that you have to ground ... I had a 1600 idle and it brought it down to about 800
sleepy
The IAC reset procedure is turn ignition off for 10 seconds, start and run engine for 5 seconds, shut engine off for 10 seconds.
I am sure you've done enough on and off, but try it this was and see if your idle changes to where it should be.
The IAC setup procedure is really setting the Thottle Body Adjustment screw. My corvette has a minimum air setting procedure, but I have not seen a procedure for SyTy. Some owners play with this screw thinking its an idle adjustment, and if had to guess your problem, its out of range for the IAC to react and the ECM to controller the idle. If you have a scan tool, I would get your truck warm, and then TB screw down until the IAC steps are in the 20 step range. Utlimately the exact number isn't important, but you want it in a range where the IAC is controlling the Idle speed.
mmp142965
Dave, where is this screw on the throttle body? is it the torx that looks like a throttle stop screw? Thanks for the tip to clean out the TB. Although it was clean, the gaskets were hard and broken. Truck runs much better.
While we are on the IAC,I have a question - is the Park and Nuetral idle speed supposed to be higher then when the truck is in gear? I have currently about 800-850rpm in nuetral and 550-600rpm in drive. niether one is rough, but I dont think there is supposed to be a difference.
Jimmy
Banned
Just jumper the A&B pins on the ALDL connector with the key on to run the IAC all the way in. Give it 30 seconds. Then remove jumper and start the engine. The ECM should find its own idle.
Yes that torx bit is TB stop screw (or whatever the official name is.
Their is two different idle speed charts for park and neutral , it really depends on the chip as to what rpm it is. Off the top of my head the stock chip is 575 (gear) and 625 P/N when fully warmed up. Their are also idle speed chart based on voltage as well, so a weak battery/alterantor could messed the different rpms as well.
mmp142965
thanks for the info! ill get a DM file of both and see what is going on.:tup:
