IAT Guage for Pillar?
just a 6
R.I.P MyClone
This is from Light duty truck fuel and emission service manual including driveability, under code 43 knock sensor.
"The PCM applies 5 volt to CKT 496. A 3500ohm resistor in the KS reduces voltage to about 2.5 volt. When knock occurs, the KS produces a small A/C voltage that rides on top of the 2.5 volt already applied. An A/C voltage monitor in the PCM is able to read this signal as a knock and incrementally retard spark"
I don't know if that helps?
turbodog
Thanks, but it's not quite what I need. The signal you quote is for terminal "E" of the module at the bottom of this diagram:
What I need are the voltages at terminal "C" of the module.
sy112
i am assuming that DRTFT means:
dont read the fucking thing?
if so, hey I got to learn somehow, but I can still complain about it :wink:
just a 6
R.I.P MyClone
Ok, the 2.5 engine have that set up for knock control.
B = ECM/IGN (C/K) or ECM 1 fuse
C = if i understand the manual right it's 12 volt and lower volt indicate knock
D = ground
E = Knock sensor
"The ECM monitor voltage on CKT 485 terminal B7, if a knock signal (low voltage) is detected but for less then 5 seconds the ESC system is considered operational and a code 43 will not set"
just a 6
R.I.P MyClone
That's true, you saw my smile right? :D
dont read the focking thing?
turbodog
Yes, I agree. Saw it on page 7-4 of the light truck manual. Output is high normally and goes low during knock. So, I need to add an inverter circuit in front of the other one.
You sure you want to use the boost guage and not the buzzer?
We can use the boost guage for IC temp, that would be easy.....
just a 6
R.I.P MyClone
I got a FMIC, did that answer your question :D Not much else to use the boost gauge for? I'm going to get a varible volt thing so i can see what volt the gauge needs for full or low needle reading. I know that the gauge don't go lower then -10 vacuum, might have to reposition the needle.
I would like to see knock on gauge and have a buzzer with a on and off switch, don't worry about the switch it self i'm going to get a nice small one. Just make the system for a switch hook up if you can.
turbodog
OK, I will forge on....
BTW, I do not think the fact that at idle, you only see -10psi is because of the guage response. A normal engine will only produce ~10psi (~20 in-Hg) of vacuum at idle. I think the guage is (sort of) accurately reflecting actual manifold pressure. The fact that the guage goes to bottom when you turn the ignition off is proof to me that the guage will read -15psi with 0 volts applied.
just a 6
R.I.P MyClone
The gauge is disconnected right now, no currence go to gauge 0 volt. Still read -10
turbodog
The I'd say your guage has a problem. Mine goes to -15 with ignition off, goes to 0 with ignition on but engine not running. you can use 1.5 volt batteries to troubleshoot. 1 cell should give ~ -10, 2 cells in series should give between +5 and +10, 3 cells should give near +15.
turbodog
Sorry, Swede... I could have sworn I already posted this, but....
Here's a schematic which includes the voltage inverter.
I also have been watching my boost guage more closely... it sometimes 'freezes' at around -10psi. Does NOT always go all the way down (with key 'off') as I stated earlier. BUT, it matches my aftermarket boost guage pretty well (at least '0 psi' = '0 psi') so I don't think anything is wrong.
Anyway, here is schematic. It will almost certainly need some tweaking to get it working just right, but this is a starting point:
Matthew Little
casper's knock gauge
The casper unit does not work with our stock sensor, They told me it would, but after several times of changing thing they said to do I took it out. I have the J+S unit now. Most likely put the casper unit in my drag car.
turbodog
Interesting. You used a knock sensor module off a Buick (or TBI S-blazer) connected to the stock knock sensor (in parallel with the connection from knock sensor to ECM)?
Matthew Little
knock
knock
Yeah, I used a gn one, that's what casper's said to do, and just hooked to the wire at the knock sensor,but no good. I wish it had worked it was a cool gauge, but I have to say I like the J+S much better. I was going to put a gn knock sensor in and just run the gauge as a stand alone, but bought the J+S, I have a the guage,esc,ks all sitting on the top of my computer desk. Iat is cool for the boost gauge, but how about having it read knock deg.? I have a temp setup With two sensors and two displays that read air intake(under truck where ram air is) filter temp(wanted to see if the ram air worked) and use my snap-on scanner to look at mat temps. I found out my heatxchanger/intercooler setup works preaty good, but I have a f2 cbr rad and a 2 gallon tank in the front, and fan on the stock xchanger.
turbodog
I agree, using it for knock retard would be cool. I tried tracing the knock signal through the schematic of the ECM at the site given earlier in the thread, but could not identify a point where the signal is easy to deal with. (as in a DC voltage).
Later, I found a site which decribes the memcal, and says that the ceramic hybrid circuit on the memcal is the knock sensor circuit. If it works like the external (GN) module, the diagram above might work with it. Anyone got a technical description of that module (input/output signals pin #'s)?
Another possible 'speed bump'... one site I saw states that any knock sensor will produce 'false' knock signals, and (especially at high RPM) the only way to distinguish them from the real thing is to compare the timing of the knock signal to the distributor reference signal, and only 'react' to those knock events which fall in the correct 'timing windows' to be combustion-related. I don't know if our ECM does this, but the boost guage (and interface circuit above) certainly WON'T, so the guage might indicate false knock, and not be all that useful.
