ic pump
Dan B
Junior Member
How can I verify ic pump is working. I tried listening for it after truck was running for a couple hours with engine off/ key "on" but didn't really hear anything....should it be loud enough to hear it running and is there another way to verify?...
SY2932
Administrator
Re: ic pump
To check your coolant flow or lack thereof, turn the ignition to "ON" but don't start the truck. Then take and paperclip and jumper the "A" and "B" pins ("A" is in the upper right hand corner and "B" is immediately to the left of "A") on the ALDL diagnostic port under the steering wheel. This is also how you pull codes form the ECM as well BTW. Take the cap off the intercooler to see if the coolant is circulating like it's supposed to. If you have your intercooler pump hardwired you don't have to use the paperclip trick.
If you don't observe any coolant circulation with the cap off, check the fuse that is behind the alternator in the weather pack connector as mentioned above. If it is blown and replacing it doesn't fix the problem, your intercooler pump is shot. You can order a direct replacement from Ron Gregory here. He has been selling Walbro fuel pumps, IC pumps and boost gauge fittings for these trucks years before I got mine. You can also order Phil Chiver's safety loops and hood prop eliminator kits from him too.
Dan B
Junior Member
Re: ic pump
Thanks fo the helpful guidence....noticed when I did the paper-clip trick w/key on engine off the pump kicked right on...opened the cap and noticed a little movement/circulation then it got kind of foamy in there....normal? Did the hot-wire mod also, couple questions come to mind.....will this mod affect driveability/reliability for any reason?....in other words are there any draw-backs to doing this mod?....Also what was the wisdom in having the computer kick on the pump @ 200+ degrees in the first place....pump longevity? emissions? etc.?....
SY2932
Administrator
Re: ic pump
A *little* foam is normal especially if the truck is hot. However, a lot of foam is not. Excessive foam is a sign that there is air trapped in the system. Trapped air will greatly reduce the efficiency of your intercooler. Air won't remove heat as quickly as water will. Ensuring that coolant is routed in such a way to keep air from getting trapped in the first place and running the pump with the cap off while topping the system off is the only way to eliminate this problem.
Bottom line is a cool motor is a happy motor. The higher your engine temperatures are, the more likely you are to experience detonation. Detonation hampers performance in two ways. First, the ECM will retard the timing anytime it detects it (unless you have a KB "kaboom" chip that doesn't have ANY spark retard :roll: ) via the knock sensor on the back of the motor. The other way detonation hampers performance is putting connecting rods through the oilpan... Therefore, preventing it is VERY important if you own a syty as our motors WILL NOT tolerate knock for long.
There are no drawbacks whatsoever from having your IC pump run all the time unless you live in a state that has emissions testing. In that case, disabling it from service during such testing will help you pass the "sniffer". If you have went the extra mile and installed a 160 degree thermostat, going back to the stock 195 degree one will help as well (remember, cooler is better). Lowering the fuel pressure if you have an Adjustable Fuel Pressure Regulator (AFPR) is another "trick" to passing.
With regards to the factory mindset, that is anybody's guess. Why install an inaccurate boost gauge in a turbocharged vehicle? Why use metal lines to circulate coolant that are attached to the top of a hot motor? Why have a wire triggers the starter in such close proximity to an insanely hot heat source? And the list gose on and on... It would *seem* that the pump coming on at the higher operating temps would be beneficial as that is when detonation would be most likely to occur. That doesn't do you any favors when the temperature is rising up to that temperature however.
