idle, extreme lean off idle stall problems
5678TA
hey guys so I jump in the Ty this morning to go for a drive and im greeted to a nice rough idle and it going super lean and stalling at throttle tip in. I pulled the IAC, cleaned it and it seems to be working as should but in DM it will jump to about 55 right at startup then slowly make its way down to 0-5. also took note that my map reading was 1.01. throttle position was fine, has fuel pressure, seems to only stall at very low throttle position. I can get it to rev through the stalling period but it just seems like that initial throttle tip in makes it stall.
i'm thinking i need a new MAP? and possibly IAC?
any help would be great. Merry Christmas
Eric Sy GN
Re: idle, extreme lean off idle stall problems
When you say the MAP reading is 1.01, is that volts or kPa? Is that at idle?
The IAC will be high when you first start, then it should work its way down to around 10-20 when warm at idle, in park. If it's hitting 00, that could indicate a bad IAC motor, vacuum leak, or for some reason the throttle blade is open too far.
Regards,
Eric
5678TA
If I remember correctly, the map was in Hg and at idle. Didnt move when I revved it.
And the iac was at 0 at one point.
WyoSyclone
Make sure your chip is fully seated. Almost sounds like you lost comm with your chip. I had that happen once and it sounds like what you're describing.
5678TA
i'll try reseat the chip tomorrow and see what happens. then if no luck, i'll get a new IAC. and finally, i'll replace the map if all else fails.
5678TA
ok reseated the chip and still got the same result. here's a quick dm file of the idle and a couple of revs. wont past 1800rpm when revved. also, wideband was reading about 15.3 at idle in closed loop and 17:1+ in open loop, warming up. i switched the MAP to KPa and it was going back and forth between 3.4 and 2.2. i feel like the IAC was still good but now, possibly MAP need replaced.
http://www.mediafire.com/?ypbkq76qpmy8vcc
Eric Sy GN
Yes, I agree something has happened to the MAP reading. Typical idle MAP reading would be 30-35 kPa. Either bad MAP, or something going on with the wiring.
Looks like I have the malfunction code threshold too low, or it would have set the check engine light (I'll get that fixed up).
Eric
5678TA
alright well i have a new map coming in the mail so hope that fixes it. i thought that number looked low... haha just kinda bummed that this had to happen on the second startup after i got my ls1 brakes in. will post my results when i get the new map
5678TA
update:
decided i wanted to take the ty for a drive so i put the stock 2bar map in and took out the turbo tweak chip(3bar). needless to say, she drove just fine. and with the recent addition of the Snow Performance Meth kit, i pulled straight to 14.5psi with zero knock. i braved it out to 14.5psi once before the meth kit and got 10 degrees retard!!
:D that is all. still waiting for the new map. I want 18psi!!!!
Flyin Ryan
hated cuz he drives fords
Glade it's just the map but I've ran 18psi without issue in the past on a stock truck with an afpr,walbro,atr chip and a wideband without any issues. I did datalog with dm to ensure no kr. All seen on 93 octane were 2 degree spikes during up shifts but in your case I'd play it safe and wait the few days for the new map to show up.
Good luck
5678TA
Bad MAP confirmed!! I installed a fresh 3Bar and she's good to go. also leaned out the VeloSyTy chip 3 points and threw in 1.1 degree of timing. Zero knock at 14psi. more testing to come.
