idle problems! help me please
So I just finished putting everything back together from the cam install. I was sure to bolt everything down to spec. I also put in a set of 50# injectors and got the chip reprogrammed for tha tas well.
I got it to fire it up and it cranks nicely and idles. Though it starts to idle a little high. Around 850 RPMs. Then after a few minutes of that, it jumps out of that rhythm and shoots up to 1500 RPM and jumps around from 1250 to 1900 RPMs. I hoooked data master up to it and prior to the erratic idle it was showing really rich, O2 mV in the 950 range, my IAC was at about 33. I would have numbers from the erratic idle part but Datamaster cut out the instant it started doing it.
I haven't tried to drive it yet like this and I won't if I don't have to. Any help is greatly appreciated.
SpoolingTurbo6
Re: idle problems! help me please
Might have been a bad burn on a chip.I've seen it happen before
If not that ......Maybe a vacuum leak.
If not that Try fuel presure
If not that Try re-addjusting the rockers
If not that SHOOT THE DANG THING
I toned down the fuel pressure a little bit adn It settled down to about 750 RPMs and stays there. Now I just have a lot of konck to deal with and figure out. perhaps fouled plugs? ;)
critical
meltdown
Did you mess w/ the throttle position sensor? Test it to make sure it is in spec. That will fool the ecu to believe otherwise. Is your tps filthy w/ oil? If so, its probly shot. Caused by a worn throttle shaft. Test tps by using a volt meter -red lead to the blue wire in the middle of tps, and black lead to gnd. Voltage should be 1.25 volts, w/ throttle closed. Key on, engine off. I used a tps from an `89 iroc 350, because they are adjustable. If you go that route, hog out the holes for easier positioning. good luck!
Alright so I found some vacuum leaks. I forgot to put the PCV valves back on and I had a slight leak where I probably should have put some teflon tape on the IA temp sensor on the upper manifold.
I still have an occasional miss. It doesn't happen every RPM, just every so often. It has me really confused.
Still running really rich too.
