Info: '41 Ford Tudor Sedan
odium
1BADGMC
I am trying to help a buddy find some information on putting a Syclone/Typhoon chassis under his '41 Ford Tudor Sedan. There is an article that shows a standard s10 4x4 chassis being put under the sedan step-by-step and it is relatively cut-free.
First, how much and where would we find a Syclone chassis. We need everything but the body, interior, and motor.
Second, I was searching through the forums looking for hot rod conversions other than the quadradeuce and came up empty-handed. There are some Fierros, standard s10s, etc., but no older cars/trucks. Anybody have some information on this?
sy538
Re: Info: '41 Ford Tudor Sedan
Just use a 4wd S10 and get the transfer case out of an Astro/Bravada. What SyTy specific parts are you looking for?
odium
1BADGMC
What exact parts would I need to do the conversion? The SyTy specific parts I would need are the frame, AWD components, and lowered suspension. Really, the article details how to use a first generation s10 frame, so I figured a Syclone chassis be much much better.
I need some specifics (parts list, etc.), otherwise I will just end up with a 2wd or 4x4 frame and a transfer case with little to no way to combine the two easily. This is why I think I would be better off finding a complete/parts of a Syclone chassis with a destroyed motor and body.
NecroWolf
lost marbles member
the frame is just a standard 4wd frame, the transfer is from a bravada/astro. i think the torsion bars are specific but why dont you just go with a coil over while you're at it. the ecm also comes in a sunbird i think? the chip is specific, the engine harness is specific, the tranny is a 700r4 w/ a specific valve body but you might as well do a 4l80e conversion. the manifolds are specific, the long block is a standard l4 w/ low compression pistons, the intake is specific, the interior is just generic s-series/jimmy w/ a specific dash cluster and the seats are covered different. and on the 93 ty's they're just leather seats like a tahoe blazer. might be easier to just do custom to begin with on a lot of the items. like a big stuff 3 ecm system w/ harness cause it'll control the engine and tranny w/ a 4l80e.
31tudor
Okay guys, I'm the sicko thinking of putting the SyTy chassis under my '41 Tudor sedan. I had posted on another board that I was looking for a first gen S-10 chassis and wicked turned me onto this idea. I can't believe I didn't think about it! But thanks Ben!
The article I have shows a 2WD S-10, not a 4X4. I don't think I clarified that to wicked previously. It's a good article, not a GREAT article. Basically, it shows how to drop a '41-'48 Ford passenger car body onto a S-10 2WD chassis. The only body modification needed is is two cuts under the rear seat so the body can fit low enough over the chassis. Of course, body mounts need to be fabricated. The Ford body on the stock suspended chassis sits as low as most hot rods sit. Of course, I'd like it a little lower than that anyway, so the SyTy would be ideal.
The article states that the car and S-10 are nearly identical weights, with nearly identical front/rear balance. Seems like an ideal swap, doesn't it?
The article talks about how all 2WD S-10 chassis are made up of two parts, a rear frame piece and a front frame piece. The back part of the front section is fishmouthed so when the factory determined what wheelbase the truck needed to be (standard cab, extended cab, short bed, long bed) they would slide the rear section into the front section to the desired length and weld it up. Supposedly it's a simple matter of grinding down the welds, adjusting the wheelbase, and welding it back up. Of course, it MUST be appropriately aligned.
So if I were able to use a Bravada or S-10 4X4 chassis, would the front/rear frame thing be the same? I'd really rather not chop up a SyTy for this, as they're already rare. And 4X4 chassis would be SOOOO much easier to find!!!
So what are the differences? I know both 4X4 ans SyTy run torsion bars, but do they have different spindles? I'm all for losing the torsion bars in favor of properly tuned coilovers. I'm also all for the 4L80E. Great tranny when built right!
As far as the T-case... I haven't seen anyone complaining about the strength of these. Is there anything I should be aware of?
Okay, commence the beating on the new guy raping a TySy chassis. Know this though, I won't do it unless it's THOROUGHLY planned out ahead of time. I won't half-ass a project, so if I choose this route it will be done right. I'm convinced that this would be the most bitchin rod I'd ever drive, but don't know if the SyTy route is worth all the extra work. It'll be a street driven car... maybe even a R&C Ego-Rama contender when finished!
Here's the potential donor. I just brought it home last night.
[image]http://www.streetrodding.com//images/messages/93067_31tudor.jpg[/image]
Robert Lone
MUTANT
Frame wise you just need to make sure you get the right frame length, S-10/S-15, extended cab, 2 door Jimmy/Blazer and 4 Door Blazer/Jimmy.Bravada have different frame lengths.
The 91-93 SyTy Chassis compare to period 4wd vehicles.
Frame is the same.
The suspension is mostly the same, the difference are the Shocks, Front Torsion bar rate (The SyTy is among the softest rate), Torsion bar Pockchops (lowers the front), & Rear Springs.
The brake are standard except for ABS, (most bypass ABS anyways).
The front and rear differential are common, the Transmission has Corvette Upgrade and a unique Valve body calibration. The Transfer case is from Bravada/Astro Van, I think the propshaft is common with a bravada, but most upgrade them because they twist and break.
'JustDreamin'
Dream: 6LV8 Turbo Bravada
Hey Boss....
Looks like a cool project....
These guys are steering you straight.
There are a number of factory wheelbases to choose from. I'd suggest you figure out which comes closest (might have an exact match, but I doubt it) and get the appropriate frame (2 or 4door blazer, std cab with short or long bed, ext cab, quite a bunch of choices).
What are you going to do for power? Any performance goals?
Personally, I think the 80E is the only way to go for reliable AWD with any kind of power and traction, especially if you're starting with nothing. You might spend a couple bucks more now, but in the long run the 80E should be a more dependable / durable unit than the 700R4 / 4L60(E)
Transfer case used in the Sy & Ty is the same unit used in Bravadas and AWD Astro's up to about '98 (BW4472) although there are some minor differences year to year (basically output shaft variations). It only has a 27 spline input shaft (vs stock 80E output of 32splines), so in order to use the 80E you've got to change the transmission output shaft to a custom 27 spline shaft. That does add work & cost to the trans, but not a ridiculous amount (especially if you're having somebody go through the trans anyway).
Only trouble with picking up the transfer case is there isn't a good way to test the Viscous Coupling inside the tcase. So, to some extent a used box is a crapshoot. It might be worthwhile to get a rebuilt case from a vendor you trust (only you can answer that) that has a new VC and a warranty. The 4x4 s10 tcases won't do AWD, they're strictly part time 4x4, so don't try and run them on the street in 4wd (probably preaching to the choir, but wanted to mention it).
I think that's all I can add to this discussion at the moment.
'JustDreamin'
Robert Lone
MUTANT
Is this true?^^^^^^^^^^^^^^^^^^
(sorry to highjack)
VermontTy
Support Our Troops
(sorry to highjack)
:bs:
Sounds completely unrealistic. Think about it....they are building pickup trucks, not friggin Lego cars.
31tudor....post that article up if you have it. I'd like to give it a browse.
Syborg Twin Turbo
Syborg Twin Turbo
A sylcone chassis and a typhoon chassis are completly different. The Typhoon chassis kicks way in, in the rear. So all 3 are different.
2wd - pro street chassis 4-sale
AWD Syclone Chassis - also 4-sale
AWD Typhoon Chassis - alos 4-Sale
ps - i am l ooking at putting an AWD chassis under a 41 Willy's PU
