gjp
another post whore
This goes part with my misfire issues but I hope to get more response by creating a new thread. Sorry.
When my truck is cold it runs fine. After warm up it runs bad(misfires). When its cold and running fine and I pull an injector wire It mimics the misfire except the misfire is at a faster rate. Because all the plugs look the same I feel its a random misfire of the injectors. The question is, What controls the injector fire sequence and because the injectors are ground pulse activaded, where is the ground wire controling them. I checked all the grounds before but I would like to isolate the specific ground wire. If the bolt or screw gets lose when the block gets hot that could cause the problem. THANKS
